Saggy Rear
Old Feb 18, 2004 | 02:46 PM
s4m's Avatar
s4m
Saggy Rear
See how the back of my truck sags to be lower than the frount. What would be the cheapest/best way to raise it up enough to make it level?
Old Feb 18, 2004 | 04:39 PM
AverysDad's Avatar
longer shackles............cheap and easy
Old Feb 23, 2004 | 02:08 PM
s4m's Avatar
s4m
who makes the best shakles for pre tacos?
Old Feb 23, 2004 | 02:31 PM
fooddude's Avatar
never knew the trucks sagged. I learn something new everyday
Old Feb 23, 2004 | 02:35 PM
Tacoma Dude's Avatar
Yeah, my rear end is sagging too (yes, yes... bring on the jokes).
If you get the shackles, don't you have to trim the exhaust?
Old Feb 23, 2004 | 03:26 PM
Cebby's Avatar
How about an "add-a-leaf"?
Old Feb 23, 2004 | 05:23 PM
Check out this post and you can weigh your options:
https://www.yotatech.com/forums/f2/beginners-guide-lifting-your-tacoma-27391/
Old Feb 23, 2004 | 07:55 PM
beefy6969's Avatar
I'm having the same problem with my 1990 ext cab 4x4 pickup.
Regarding shackles,add-a-leafs...how hard is labor on these? how much will labor cost on these?
On another thought, if i was to install a body lift, can i just double up on the blocks in the rear?
Old Feb 24, 2004 | 04:45 AM
CTB's Avatar
CTB
What do you mean by "double-up?" A body lift won't change your suspension.
Old Feb 24, 2004 | 05:00 AM
rimpainter.com's Avatar
Add a leaf...
Old Feb 24, 2004 | 11:54 AM
Stay away from the blocks. Bad idea - check out the previous link I posted. There is an article available on the types of lifts for p/ups and the pros and cons of them.
Old Feb 24, 2004 | 12:28 PM
X-AWDriver's Avatar
So,how much is your rear end sagging?
Old Feb 24, 2004 | 12:31 PM
X-AWDriver's Avatar
It's sagging so much that when I was tailgating you I thought I was behind Nick Nolte jogging in the nude.
*doh!!!*
Old Feb 24, 2004 | 12:36 PM
*groan*
Old Feb 24, 2004 | 03:39 PM
Paul H.'s Avatar
My 2wd Nissan's rear is sagging too but the leaf springs are under the axel. What is the best way to level or lift this setup?
Old Feb 24, 2004 | 03:40 PM
Rancho air shocks with on-board compressor. They work great.
Old Feb 24, 2004 | 04:48 PM
86toyota's Avatar
I posted earlier about springs on a diff thread. I replaced my stock springs on my 92 with stock aftermarket springs,measured before and after.......raised it 2 1/2".Previousley I added 1.1/2" shackles paid $50 for them but had to torch out old rear bushings which added another $15.
Old Feb 24, 2004 | 07:08 PM
hey s4m,
i don't think your truck is saggin that much...hte pickups form 89-95 have a lower fender well in the rear...if you look at your body line down your box and door you can see this...i think you should only fix this is you want more Rake on your truck..but its up to you
cody
okamikai
Apr 30, 2018 10:19 PM
kirkrunner
Jul 27, 2015 07:59 PM
SMOD
Jul 27, 2015 01:45 PM
Athansinis
Jul 27, 2015 08:38 AM
icentropy
Jul 14, 2015 10:23 AM
