Noticed something weird when I changed my tranny Fluid
Hey guys!!
I wanted to run this past you guys to see if any of you had this issue
I changed the tranny fluid in my truck over the weekend by dropping the pan and cleaning the filter. Any way on the dipstick there is a section for hot and cold marks. I had a heck of a time getting my fluid in the normal range in hot. But the next day I checked it after sitting over night and it was above the marks cold. My question is...Has anyone noticed this? I never check it before cold.
My second question is.....When do you check it hot. I waited after about a 14 mile drive and checked. Was it now too hot?
And Third......How much fluid has anyone put back in it after dropping the pan and filter? I measured what came out and it was about 6 quarts. Is that too much? It was always in the normal range when it was warm.
Thanks guys!
Thanks guys!
I have a 96 4runner and Toyota recommended not dropping the pan to do a service change. Supposedly the filter is supposed to be a non serviceable unit? Anyways, I run a bit more fluid than spec and it seems to shift smoother than way. Less fluid and it shifts sporatically. I think you'll be alright, just run it for a bit and see how it performs. BTW, a 14 mile drive is not too long. the fluid should remain at an ambient temperature once it warms up
I would not suggest to never clean the filter.....in fact if you leave it too long you are asking for problems. The filter is a lifetime unit but that just means you dont replace it, not that it doesnt need to be cleaned and serviced.
Originally Posted by Mikey
Hey guys!!
Thanks guys!
Thanks guys!
As long as you were not towing a trailer or driving in city traffic on a very hot day you should'nt be above the normal temp.
I went by the Hot marks. I figured that it would be the most accurate since the tranny's warm and the fluid is actually flowing.
Does adding six quarts back in seem normal. The toyota dealer said that I should only add about 3 back in. Not that I beleive them or anything.
3 quarts is about right. Make sure you check the level as described above. DO NOT check levels of lubricants with the vehicle parked on your driveway since it slopes and your readings will be off. Move the vehicle to a flat area.
I did make sure that it was level. I learned from experience one time on that one :pat:
I checked it again (Hot) and it was in the right range again. So everything is cool. Just weird that it took that much fluid to everybody elses.
5-6 quarts is about right and slightly over the mark on these units is not harmful either, it may actually be a little better.
-John
jasonty
41
Dec 23, 2018 01:00 PM
icentropy
Jul 14, 2015 10:23 AM
madxman21
Jul 9, 2015 10:26 AM
