new issue with the runner...
Old May 18, 2008 | 04:12 PM
brandyn85's Avatar
Question new issue with the runner...
so i replaced the shift solenoids in the 99 runner and everything was awesome for a while, then my girlfriend called me about a week ago on her way to dinner with her mom and said she was driving normal at about 45mph and all of a sudden the truck just revved like it was in neutral.. i just told her to shift down and limp to where she was going. and i would check it out when she ot home well on the way back she said it was fine. i drove it and it was alright then it started doing it again the next day. so i turned overdrive off because it seemed like thats what gear it was shifting into, well with overdrive off it doesnt do it.... i did a search and didnt see anything with this year... i was thinking about changing the filter and fluid again... fluid was just done a few weeks ago but the filter was done way back when the tranny overheated and mixed the coolant and trans fluid... once that happened i flushed the tranny 3 or 4 times and then put a new filter on... so the filter has probably only been on for 8 months or so..... any input??? im starting to think i need to just get another tranny and stop trying to save this one. also no check engine light or anything... and i checked the fluid level and it looks alright
Old May 18, 2008 | 04:27 PM
Man4God's Avatar
I don't know but you are scaring me. Why did you replace the solenoids? Cause of the overheating? Did you put shims in along with the solenoids?
Old May 18, 2008 | 04:31 PM
BigBallsMcFalls's Avatar
u need real transmission work. did you flush 45 liters of fresh trans fluid through
it with a computerized positive pressure system ?
Old May 18, 2008 | 06:30 PM
brandyn85's Avatar
well i posted up about the solenoid issue before... it wasnt shifting back into first when coming to a stop... thats how those came into affect... there was no shims required with them....
Old May 18, 2008 | 07:27 PM
1989toy4wd's Avatar
Your trans fluid was mixed with coolant, and you only flushed it??!! If that ever happens you are supposed to overhaul the tranny and replace the torque converter.
I bet your problem is caused by coolant in the fluid! I would say its time for an O/H and new torque converter!! Sorry for the bad news!
Old May 18, 2008 | 07:30 PM
1989toy4wd's Avatar
You can always taste the fluid, if it is sweet, then you have coolant in it (yes this is a legitimate way of testing fluid). Just pull the dipstick and wipe your finger on it and taste it.
Old May 22, 2008 | 07:06 AM
brandyn85's Avatar
no coolant in there... i added some lucas stop slip yesterday and it seemed ok, but i didnt go too far
Old May 22, 2008 | 08:19 AM
mkgarrison5's Avatar
gya you added lucas? good luck with that.. how many miles on the tranny? and what fluid are you using? dex3???
Old May 22, 2008 | 08:21 AM
sure you go ahead and increase that risk of cancer... couldnt he just look at the fluid closely to see if its a milkshake??
Old May 22, 2008 | 08:31 AM
one taste of coolant won't hurt anything. it's not like you are brushing your teeth with it daily
Old May 22, 2008 | 08:51 AM
to each their own bubba.. its not listerine ya know
Old May 22, 2008 | 09:15 AM
brandyn85's Avatar
105k on the tranny... my girlfriend took the runner to work today and she said it seemed to be better so i will check it out later today
bigjstang
Jun 2, 2025 03:56 PM
nvdesertrunner
May 11, 2020 08:18 PM
crammit442
7
Nov 29, 2017 12:30 PM
raptor510
Aug 19, 2015 02:15 PM
rjtrials
Aug 6, 2015 07:25 PM
