motor bad on the back window
On my 4runner i am trying to get all the little things to work right. Back window does not work. PO said it was off the track, i looked fine to me. No noise are anything from the motor on the window. No idea what is wrong with it. not sure how to test for it either. As always thx guys mike
Here's a link to check out, maybe Roger will chime in, he's the master of all things 4Runner!
http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
Originally Posted by 854runner
WOW, what makes it 250?? alot more then i thought it would be.
mike
mike
it was 250 for a new one....and I don't think it was an original part, somethin else, but It came with a warranty, don't remember how long. When it comes down to it. Its worth it rather than searching ebay or junkyards, since you'll spend way more time than its worth than taking it to a shop and letting them fix it.
Pull the gate trim and metal cover panel. Unplug motor and jump it with 12 volts. Change polarity to reverse direction. To pull regulator assembly disconect wires, latch & lock rods and lock cables. Remove the four 10mm bolts, slide towards passengers side and tilt to lower into gate. Slide from side to side to disconnect from glass channels, unplug wires from glass and remove. Remove regulator assembly by tilting top up as you slide towards drivers side. Most common trouble with regulator is worn out / missing nylon wheels in end of arms. Check teeth for wear, when removing motor be ready for spring loaded arms to fly up when motor gear disengages. Used motor is $20.00 to $40.00, complete regulator assy $30.00 to $75.00 depending on condition. Can be replaced in 15 minuets if you have done the job before.
thx guys link does not work for me.
What "does not do a thing"? If you are referring to the entire truck, then yes, a fusible link would be susepct, since almost *everything* electrical on the truck (outside the starter) runs through the fusible link. If you are only referring rear window, then continue on down the troubleshooting steps.
voiddweller
19
May 2, 2016 09:10 PM
WTB[SouthEast]: 2001 Tacoma Passenger Side Power Window Harness
scottt80
Jul 1, 2015 12:13 PM
infinityisfive
Jun 16, 2015 06:51 PM
