Lift this weekend, any pointers????
Re: Lift this weekend, any pointers????
Originally posted by Mad Chemist
Okay folks, will be installing OME coils and shocks in the back, SAWS in the front. Pointers I've run across-
1) make sure the longer of the two OME coils is on the gas tank side of the vehicle, regardless of what the label says.
2) Spray penetrating oil on everything the night before to ease loosening of bolts.
3) Install SAWS valve facing inboard.
4) Measure before and after install to get an idea of lift.
Any other tips? Did you guys disconnect the rear brake lines during the install?
Re: Re: Lift this weekend, any pointers????
Originally posted by keisur
Make sure you put the Taller OME Spring on the drivers side. I have to pull mine off tomorrow to make sure I did when I installed them a year ago. either they are in wrong or they are sagging. gonna throw in some trim packers while I'm at it.
Originally posted by <96 Runner>
Dang all these 4ROC emblems!
You guys look like a gang or something.
How do I get jumped in?
People, people.....
The avatars aren't a permanent fixture, they're out in force in order to, shall we say, 'promote awareness' of the 4ROC movement.
Man, I've been out in left-wing USA way too long if I'm starting to use phrases like 'promote awareness'.
#25
Originally posted by mertztr
People, people.....
People, people.....
oh, just keep from using a phrase like "paradigm shift" and you should be ok living on the "left" coast.
#27
Haha, paradigm shift....yeah I've heard that one at one too many feel-good company-wide meetings. We should start a list of all the BS business catch phrases out there!
Jcrawl94
10
Oct 24, 2015 04:34 PM
punks_is_4x4
Aug 21, 2015 01:35 PM
