k&n intake silencer mod?
Old Sep 6, 2012 | 09:59 AM
demonrunner16's Avatar
Can i do the silencer mod on a k&n intake or can you only do that on the stock intake?
Old Sep 6, 2012 | 10:27 AM
warpigg's Avatar
does the k&n tube that goes from the maf to the throttle body have silencers?
Old Sep 7, 2012 | 05:27 AM
Texas_Ace's Avatar
You would make more power going back to the stock intake anyways so I would not worry about it.
Old Sep 7, 2012 | 02:50 PM
so youre saying the stock intake is better than the k&n?
Old Sep 7, 2012 | 02:55 PM
konah's Avatar
That's what it sounds like to me.
Old Sep 7, 2012 | 03:10 PM
Texas_Ace's Avatar
Yep, dyno proven by me and Gadget. Stock intake with Elbow removed is the best intake for our engines. Our engines just don't response well to bolt on's. The only way to get more power out of them is to boost them.
Here is a dyno test I did back to back on the dyno and repeated twice because I did not expect the results.
Blue = Stock with elbow removed
Red = "cold air" intake
If you want the feeling of more power and for some reason don't want to boost it you have 2 other options. You can get gears, this will hurt your MPG but it will feel a lot faster. or you can get a high stall converter for the transmission, this will make the power from a stop much nicer.
Old Sep 18, 2012 | 10:44 AM
SierraMtns's Avatar
I am glad I saw this and did not run out and buy the K&N intake system. Have you Dyno tested the Intake Silencer Mod? Also which elbow are you talking about that you removed?
Thanks
Old Sep 18, 2012 | 11:00 AM
Texas_Ace's Avatar
Thanks
pretty sure I show the elbow in that video. It is the one that goes into the fender.
https://www.youtube.com/watch?v=jr13...8CCC011FCA0FCB
no need to test the intake silencer, removing it should not make anymore power and the butt dyno agrees. I only did it for looks and to make checking the transmission easier.
punks_is_4x4
May 31, 2016 06:03 AM
voiddweller
53
Feb 1, 2016 05:46 AM
JookUpVandetti
Sep 17, 2015 09:25 PM
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
Boomer8404
Sep 10, 2015 09:01 AM
