Intake Silencer Removal Question???
Old Jan 1, 2004 | 01:04 PM
Guerrero's Avatar
Question Intake Silencer Removal Question???
After searching for this mod, I haven't been able to find the answer to my question...
Where should I connect the FPR hose, I have a 2000 SR5 2wd.
I read:
"2002 Intake Silencer Removal Mod 3rd Gen 3.4 Engine:
Paul (ALBPM)"
"Intake Silencer Removal Mod 3rd Gen 3.4 Engine:
Galen (Dr. Zhivago) "
Those instructions are for a 4x4 and I don't have the hoses that they are using to connect the FRP hose.
I initially pull out the hose and put a 7/32 vacuum cap on there.
If I do that, I will have full pressure at all times. My question is, how bad is to have fuel pressure at all times?
I have the 2 1/2 sch .40 PVC tube I want to chage it for the stainless pipe. Where can I buy a stainless pipe to replace the silencer box?
Thanks in advance.
Old Jan 1, 2004 | 01:06 PM
Spectre's Avatar
dude..you were just reading my mind..I have been trying to search for this here too...
Edited for Content.
Cebby
Old Jan 1, 2004 | 01:07 PM
rimpainter.com's Avatar
Follow Dr. Z's recommendations. It's not bad to run with the FPR plugged all the time. Dr. Z has found that to be the best set-up for the 99's and up. The 96 - 98's are a different story.
As for the stainless pipe, I think most guys got it at a muffler shop.
Old Jan 1, 2004 | 01:31 PM
Spectre's Avatar
I could not find anything when I did the search...
I am interested in reading both "2002 Intake Silencer Removal Mod 3rd Gen 3.4 Engine:
Paul (ALBPM)"
Old Jan 1, 2004 | 01:41 PM
Guerrero's Avatar
Paul (ALBPM)"
Check the link below and go to the performance page:
Good link to have
Old Jan 1, 2004 | 01:54 PM
Guerrero's Avatar
My next question is, if is not bad to have pressure all the times, why do our rigs have a Fuel Pressure Regulator for?
Thanks for all the help
Old Jan 1, 2004 | 01:57 PM
Spectre's Avatar
Good link to have
Thank you
Old Jan 1, 2004 | 09:19 PM
ALBPM's Avatar
After Dr. Z discovered that it was better to run with the FPR capped. I disconnected the FPR from the plenum on my 02 4x4.
I thought it would be best to have some vacuum on the FPR so I went back to my original setup using a "T" and connecting it to the EVAP hose.
Old Jan 2, 2004 | 04:12 AM
I dont think Toyota figured we would be removing their silencers and cutting in deckplates.
It also may have something to do with open and closed loop operation. Dr Z could explain it better. Where is Galen anyway?
kazuya2416
Apr 5, 2024 02:17 AM
Doug4320
Mar 24, 2018 10:11 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
coffey50
Jul 28, 2015 10:55 AM
icentropy
Jul 14, 2015 10:23 AM
