Hot start stall problem...fixed!
Old May 5, 2007 | 11:22 AM
BajaRunner's Avatar
I went and cleaned the Idle Air Control today, located underneath the throttle body. Went for a test drive and it seemed back to normal. It had gotten to the point that I would stall out at stop lights, and even during cold starts. :/
So I took some of the hoses off the unit, and it spewed a good 1/4 cup of liquid. It resembled brake fluid. Anyone have a clue on what it could have been?
I did the same thing as this guy:
https://www.yotatech.com/forums/f123/re-3-4l-v6-hard-start-hot-cleaned-iac-pics-92286/
Old May 25, 2007 | 07:50 PM
hydrochskier's Avatar
Just curious but, where exactly is the idle air control because my 4runner will stall randomly sometimes?
Old May 25, 2007 | 10:37 PM
BajaRunner's Avatar
Right underneath the throttle body. (aka Butterfly valve).. Follow the air box hose into the engine ... thats the throttle body. You take that out, and right below there is a sensor and another chamber that tends to get gunked up.
Old May 26, 2007 | 08:45 AM
Thank you! Maybe this fix will solve my random stalling problems.
Old May 30, 2007 | 07:53 AM
Ron Helmuth's Avatar
Thanks for posting up what the trouble was-this is most helpful to all of us fellow 4Runner owners.
glad to hear that frustration is solved.
Old May 30, 2007 | 10:08 AM
gpcollen1's Avatar
Shouldnt that have been coolant? Brake Fluid ?-? in color only I guess?
Old May 30, 2007 | 12:25 PM
BajaRunner's Avatar
Donno, it I think was oil.
Old May 30, 2007 | 02:11 PM
Crazychopstick's Avatar
It was probably just built-up oil residue from a normally functioning PCV system.
Thanks for posting up this solution, I had my Runner stall once in the middle of rush hour on an uphill slope. So maybe I should go ahead a clean this out.
But I was wondering, should the IAC have a bit of oil as lubrication?
And, did you replace all the o-ring/gaskets?
bigjstang
Jun 2, 2025 03:56 PM
Charecter1
Nov 6, 2023 10:08 AM
Poncho0206
Jul 10, 2015 06:21 PM
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
