Hood vibration
Old Apr 28, 2003 | 11:41 PM
JaRuEL's Avatar
Hood vibration
I went on a trip last week and noticed the hood vibrating so badly. I thought the hood was going to come off! Has anyone else experienced this? Is there a fix to this problem?
Old Apr 29, 2003 | 03:14 AM
WT's Avatar
WT
Re: Hood vibration
From what I remember some 3rd gens see this due to wind deflector on the front, wierd but i have heard that before somewere. Mines not to bad and I have the factory deflector on it. guess it could be said its normal
Old Apr 29, 2003 | 04:59 AM
Outkast`'s Avatar
Yeah Jaruel,
I have the same issue with my hood. It was suggested to me as well that I get a bug deflector and that it would cut the vibrations down significantly...just haven't gotten around to that 'mod' yet. If I hear anything else I'll be sure to post it.
My $0.02,
Outkast'
Old Apr 29, 2003 | 05:31 AM
1Runner's Avatar
Gentlemen, try adjusting your hood stops. Pop your hood, at ea. corner there is a adjustable "snubber" on a bolt. Adjust them both to raise up approx. 1/16 of an inch. Close your hood, and go for a spin. Trust me.
Old Apr 29, 2003 | 05:38 AM
Outkast`'s Avatar
Smile
Hmmmmmmm,
Sounds interesting...We'll give it a run and let ya' know how it turns out.
Thanks for the Info,
Outkast`
AznSky's Avatar
Would you by chance have any pics with directions on how to do this? Oh yeah, and when I say "directions, I mean "Dummy Arrows"
Old Apr 29, 2003 | 06:26 AM
rimpainter.com's Avatar
On the contrary, I feel the bug guard may cause the hood vibration. I do not run a bug guard, and my hood is fine while driving.
The hood stops are at the front of the engine bay, at each corner. To adjust them, turn left for "up" and right for "down."
In the case of a hood vibrating, I would lean toward adjusting them up.
This may not solve the problem, as my old Tacoma had this problem, and nothing would fix it. There are even guys selling a kit that allegedly fixes this problem once and for all.
Old Apr 29, 2003 | 07:52 AM
Jason B's Avatar
www.flankersolutions.com
Old Apr 29, 2003 | 08:12 AM
JaRuEL's Avatar
Outkast,
I do have the bug deflector. The vibration is towards the windshield. The hood was steady in front where the bug deflector is. Anyone who experienced this can attest that it's a scary one.
I will try adjusting my hood stops as some suggested and hopefully that will cure this. Thanks everyone.
Old Apr 29, 2003 | 09:23 AM
Try taking the bug deflector off first, then see if you still have the symptoms. I think its the deflector that amplifies this problem.
Old Mar 19, 2015 | 04:33 AM
toyfan1's Avatar
4Runner Hood Vibration - Toyota Fix
I also had viibration on rear the edge of the hood on my 97 4runner with Toyota bug shield. Adjusting the front stops upward reduces the vibration, but resulted in hood sitting higher than fenders in the front.
My son has a 2004 Tacoma double cab. I noticed the Tacoma cowl cover has a rubber bumper mounted in the middle on front edge of cowl. No hood vibration on the Tacoma with bug shield.
I tried the Tacoma cowl and it fit perfectly on the 97 4Runner. The Tacoma cowl totally eliminated vibration on the rear edge.
The part number stamped on the Tacoma cowl is of Toyota 55708-04030 and 55708-04040. I ordered the 55708-04040 cold weather cowl, installed today.
Another option might be to attach a rubber block to 4Runner cowl cover.
2004 Tacoma Cowl Information from Online Catalog:
55781F 5570804040 LOUVER, COWL TOP VENTILATOR. COLD AREA PACKAGE TACOMA $110.84
Old Apr 15, 2015 | 06:22 AM
dallison's Avatar
Our 01 sport hood shakes pretty bad. I'll have to try the rubber bump stop adjustment.
Old Apr 18, 2015 | 07:45 PM
ThorInc's Avatar
1Runner is exactly right. At each corner along chassis directly above the head lights, black circular rubber stops about a quarter in diameter, turn counter clockwise to increase their height. The hood should then require more pressure to close.
ashamsuddin
17
Jul 22, 2024 03:59 AM
Davebarbier
Nov 3, 2015 03:28 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
JPV
Sep 28, 2015 03:15 PM
Odin
Sep 26, 2015 06:56 PM
