High NOX second failure
Hello...I have a 99 2wd 4Runner SR5. Took it in for emissions test last week and it failed because the NOx GPM was 2.12 and the limit is 2.0000.
So i took it to a repair shop and he said the vacuum was ok and he cleaned the MAF sensor. I also replaced the air filter with a FRAM tough Guard CA7626. Took the 4R back to emissions today and it failed again. This time the NOx was 4.0419.
So now what...The vehicles has 198500 miles. The tech at the repair shop said next step would be to replace the catalytic convertor. But after reading on these forums it seems like replacing the O2 sensor might be the answer. Any thoughts?
Thanks
Thanks
Try running some alcohol in your fuel for the test. I've heard a bottle of rubbing alcohol works. I might look for an e85 pump and put in a gal or 2 for the test then fill up with regular fuel to dilute it down after the test because alcohol is hard on parts unless the vehicle is designed for flex fuel (FF). Nox is caused by high combustion temps. Running lean makes for higher combustion temps so I'm not surprised it was worse with the new air filter.
What exactly does running lean mean? does that mean that the air to fuel ratio is more air than fuel?
Also the mechanic where i brought this in for the first fix said that the engine has blow by, because there was some oil on the air filter? is this the beginning of the end of this truck
Thanks
Thanks
Thanks
Thanks
Yeah blow by is not a good sign, but you have to expect some engine wear at nearly 200K miles.
Thanks
Thanks
Yeah Roger they did away with the EGR on the 5VZFE in about 96 or 97.
Here's some more ideas: https://www.yotatech.com/forums/f2/f...-check-106293/
OK, did not state what engine he was referring to in the post. I also found that retarding timing a few degrees helped with NOx along with running some premium gas, not sure if you can do that on the newer engines either.
I quote from that link I posted earlier:
Longbed 90
Mar 11, 2019 12:38 PM
_Nicco_
Sep 21, 2015 03:06 PM
