HELP!!! reverse glow gauges!!
Old Sep 23, 2003 | 02:53 PM
dexter's Avatar
i got a package deal off ebay for silver faced gauges and some crappy bulbs that i sold to a friend and followed the write up in the formums perfectly. at first only the far write engine heat light would turn blue now none of them will. they came in an r otto racing box (alfaroto.com) they fit on the gauges and allowed the needles to move withouit any cutting or drilling. i drilled the holes in the white gauge cluster etc etc. WHY WONT THEY WORK????
thanks
Old Sep 23, 2003 | 05:18 PM
dexter's Avatar
anyone out their???
Old Sep 24, 2003 | 08:44 AM
Rayday81's Avatar
Sorry man I can't offer any help for you, because I've never done this, but I though I'd give you a BUMP
Try another forum, there is a forum called ToyotaNation.com I believe. Anyway there are more than just trucks there and a lot of guys there are more into cosmetic upgrades and such. Just a suggestion.
Old Sep 24, 2003 | 10:22 AM
Mad Chemist's Avatar
Have you blown a fuse? Did you check the wire with a tester to make sure you've got juice going to the gauges?
Old Sep 24, 2003 | 11:32 AM
dexter's Avatar
no i havent how do i do that?? the corner light will still work as will the stock gauges behind. the fyse in the fuseholder is still good maby its the black box thing all the wires go into and out of, but id have to buy a whole new set of gauges
Old Sep 24, 2003 | 12:11 PM
Okay, so if you're getting at least one blue light on the new cluster, it probably isn't a fuse issue, since its getting some power. Have you tried adjusting the intensity of gauges? Maybe its turned down too low? Have you looked at them at night? Who made these gauges?
Old Sep 24, 2003 | 07:01 PM
dexter's Avatar
at first only one worked then they all stoped working. i have messed with the ilumination and have looked at them at night but to no avail.
they are made by r otto racing. website is alfaracing.com or something like that but i won the auction from pro car parts. i emailed the r otto company 2 days ago and havnt heard anything this really sucks.
Old Sep 25, 2003 | 06:28 AM
Huh, I got mine from procarparts, and didn't have any trouble at all. So, if none of them are working at all, I would double check all your wiring. What did you connect the positive and ground wire to? Check the connections on all the wires to make sure nothing got pulled loose. Go to Walmart or Napa or whereever, and buy yourself a cheap voltage tester. Its bascilly a pointy looking thing with a lightbulb, with a wire with an alligator clip on the end. You ground the clip, then push the pointy thing in the wire that should have juice flowing to it. The light should turn on if you've got power flowing to the cluster (make sure the vehicle is turned on).
Old Sep 25, 2003 | 01:00 PM
dexter's Avatar
k ill get one. i hooked them up and made a new ground (all metal no paint) and connected them to the front conrener light which still lights up.
ashamsuddin
17
Jul 22, 2024 03:59 AM
kawazx636
Oct 6, 2021 03:03 PM
zanzabar0
Oct 11, 2015 02:56 AM
the_supernerd
Oct 1, 2015 09:20 PM
dbollier123
Sep 29, 2015 05:23 PM
