Help Needed...Panhard Drop Needed?
Old Sep 24, 2003 | 10:53 PM
emptyd's Avatar
Help Needed...Rear Panhard Rod Drop Required?
I'm sorry if I am beating a dead horse...I am confused as to whether a rear panhard rod drop is necessary after installing the rear OME HD Spring/shock combo.
I seem to recall some info. on relocating (moving UP) the driver's side as opposed to dropping the passenger side. Any help on the following would be greatly appreciated:
1. Do I need to relocate the panhard rod?
2. Is it because the angle after the lift may cause alignment or performance issues?
3. Do I go UP with the Driver's side or DOWN with the Passenger side?
4. Is there a bolt-on kit or is welded-on the only option.
5. Where can I get the recommended kit?
Also, My eBrake lite is coming on. How do I adjust/modify this system? Does someone make a kit or is there a parts list for a self-mod?
Thanks all.
Matt
Old Sep 24, 2003 | 11:22 PM
Cebby's Avatar
I think you mean panhard rod.
If it (PR) is at a severe angle, you'll have a) driveshaft hitting gastank skid under extreme articulation and b) vehicle not tracking straight.
You can get bolt on ones, but I think they are parts of lift kits typically, so weld on might be your only option. (not 100% sure on that). You go "down" on the passenger side.
You can try Sonoran Steel (schaefer3) for a weld on model.
For the brake issue, it's just a plate - easily fabbed. Someone with a 3rd Gen got a pic?
Old Sep 25, 2003 | 12:07 AM
emptyd's Avatar
[QUOTE]Originally posted by Cebby
[B]I think you mean panhard rod.
Cebby
Oops!...Thanks for correcting me.
Matt
Old Sep 25, 2003 | 12:31 AM
44Runner's Avatar
Here are some pics:
Old Sep 25, 2003 | 12:54 AM
emptyd's Avatar
Looks like you have both the Panhard (Driver's side) lift AND (passenger side) drop. Any particular reason? I've got 3" rear lift, do you have more?
Old Sep 25, 2003 | 02:55 AM
The Nak's Avatar
Or, if you'd rather just through some money at it, Downey has a bracket. It just looks like a piece of flat steel, with 5 holes and 2 bolts. Part #48211, $8.25.
Good Luck,
Nak
Old Sep 25, 2003 | 06:04 AM
Cebby's Avatar
Originally posted by 44Runner
Here are some pics:
I've never seen both sides "adjusted". That's a new one on me. I've only seen the passenger side dropped.
EDIT: I just realized who posted that. 44Runner has a ton of rear lift to go with his Dana 44 SA up front.
Old Sep 25, 2003 | 08:38 AM
emptyd's Avatar
Nak,
Downey claims "no can do"...the drop brackets they sell are only for the 90-95. My rig is a 2000.
Anyone familiar with ProComp's offerings? I know that they used to make one for the 4Runner (maybe earlier versions as well)?
Old Sep 25, 2003 | 08:54 AM
keisur's Avatar
Originally posted by emptyd
Nak,
the only option that fit ours are the weld on type that Steve Schaefer designed.
Old Sep 25, 2003 | 09:07 AM
The Nak's Avatar
Nak,
I was only referring to the bracket for the brake issue, sorry for the mixup.
Nak
Old Sep 25, 2003 | 09:29 AM
keisur's Avatar
Nak
go to lowes or homodepot and get a 3 inch flat bar maybe 1" wide and 1/16" thick and drill two holes 2.5" apart and unscrew the ebrake and bolt it to the bracket and then use the screw you pulled to screw the bracket to the ebrake mount on the diff. don't buy one, if they are even available, it's cost like $1 to do.
I just used a strap from the door hardware section and enlarged the existing holes.
Old Sep 25, 2003 | 09:36 AM
waskillywabbit's Avatar
A little thicker perhaps
I agree, except I would go a bit thicker than 1/16, perhaps 3/16, as that is the thickness most "fabbed" ones.
I fabbed mine out of 1/4" because I didn't have any 3/16, just takes a bit longer bolt.
My 0.02
Brian
Old Sep 25, 2003 | 09:42 AM
emptyd's Avatar
Keisur,
THANKS! Pics. and everything - you rock.
Matt
Old Sep 25, 2003 | 09:59 AM
keisur's Avatar
Re: A little thicker perhaps
My 0.02
Brian
I think you should just use a strip of tinfoil folded in half you alabama redneck!
really, I think mine is about 3/16". It doesn't really see much load, it just holds the cable housing so it doesn't get hung up in something or deflect when you rip up the ebrake to pull donuts in an icy parking lot.
Old Sep 25, 2003 | 10:05 AM
Re: Re: A little thicker perhaps
Don't give away all my secrets! Next you'll be telling them about my super duper secret rusty coat hanger custom made antenna!
Brian
Old Sep 25, 2003 | 10:17 AM
keisur's Avatar
Re: Re: Re: A little thicker perhaps
Brian
that was supposed to be a secret? oops.
on topic: just make sure you hold the strap in a vise when you go to enlarge the holes. I was doing mine while laying under the rearend and about lost my fingers because I thought I was superman and tried to hold one end drill the hole. when it finally popped through I let go fast enough to just scare the buhjeeziss out of me, then I crawled out and clamped it in a vise and finished the job.
Old Sep 25, 2003 | 02:30 PM
emptyd's Avatar
Re: Re: Re: Re: A little thicker perhaps
Thanks for the heads up...unfortunately, the only vice I have is a penchant for drinking. I'm working on that though.
Old Sep 25, 2003 | 02:58 PM
keisur's Avatar
Re: Re: Re: Re: Re: A little thicker perhaps
Are you talking about the police? just kidding.
In that case you could just hold it in your teeth and drill the hole. who needs those things anyway, they seem to do alright here in Texas without them, I'm talking about teeth.
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
BigArt70
Jun 30, 2015 09:51 PM
HALMAN
Jun 14, 2002 09:02 PM
