Help, my engine has a hard time starting!
Old Sep 26, 2009 | 08:35 PM
trcooperone's Avatar
I have a 2000 4runner with a 3.4
My runner has been having a had time starting lately and I am having a had time figuring out what it is. When I go to turn the engine over when I first get in the car it is dead and it take s a min and a few more cranks for it to turn over.
I have checked the battery and I have a full charge. I have also checked the starter and It is also good. I think it might be a bad connection some where but I don't what to do next to diagnose the problem.
Any and all help would be great. My wife needs the car back together by Monday morning so she can get to work.
Thanks!
Old Sep 26, 2009 | 11:48 PM
brian2sun's Avatar
Do you mean cranks on the key or does the engine crank over and not fire up?
Old Sep 27, 2009 | 06:20 AM
cranks on the key, the engine does not turn over the first couple of turns with the key.
Old Sep 27, 2009 | 08:45 AM
BajaRunner's Avatar
Do you ever get nothing, or a just click sound when you turn the key?
Whats your battery voltage?
Does the starter seem sluggish at all?
Old Sep 27, 2009 | 09:00 AM
Yes when I first try to turn the motor over I get nothing, then the starter will click once and then it will turn over
Old Sep 27, 2009 | 09:37 AM
brian2sun's Avatar
Sounds like the contacts on your starter are worn out (the "click" is the tell-tale sign). A lot of people replace the entire starter assy., but it's not necessary in most cases, just the contacts will usually fix the problem. Replacing them is cheap and fairly easy. Do a search and you'll find a lot of info on this.
Old Sep 27, 2009 | 11:57 AM
Is this what I need?
http://shop.oreillyauto.com/productd...Number=ND34SOL
Old Sep 27, 2009 | 09:09 PM
brian2sun's Avatar
Yes, except I would buy Toyota OEM parts. Not much more $$, but way better quality than aftermarket brands.
Old Sep 27, 2009 | 09:11 PM
well the dealership was closed by the time I was able to do anything, I did get the parts from the parts store and got the new contacts installed and we are back in business. THANKS to everyone who helped out.
Old Sep 27, 2009 | 09:15 PM
brian2sun's Avatar
Good to hear!
Old Sep 30, 2009 | 06:32 AM
Alright so I got the starter fixed and back in and the car and it started great, then today I went to leave and It wouldn't start!
I don't get any clicking noises but I have power to everything. What is wrong? Is it a bad starter?
HELP!
Old Sep 30, 2009 | 08:17 AM
BigBallsMcFalls's Avatar
HELP!
likely not a bad starter, ...bad starter repair. you have to tighten down the new contacts exactly like the toyota TSB with the right torque and a block of wood in a press. it is far too easy for them to become misaligned.
Old Sep 30, 2009 | 10:41 AM
eddieleephd's Avatar
Check all grounds this is a big issue on all vehicles that runs people in circles ground to battery and Engine. Make sure the contact surface between the starter and engine is clean.
JF9243176
Oct 8, 2017 04:21 AM
ZONAYODA
Jun 30, 2015 05:36 PM
renorunnerguy
3.4 Swaps
Jun 28, 2015 09:18 AM
JF9243176
Jun 24, 2015 04:53 AM
David_Vestfal
Jun 20, 2002 08:30 PM
