HELP!! all people who have installed headers on the 3.0....
Old Jan 22, 2004 | 06:53 PM
joeal's Avatar
How did you get the header in on the passenger side?!?! I've come this far and I'm getting a lil frustrated and short tempered but anyone got any tips on how they got theres in? all help is welcomed!!
Old Jan 22, 2004 | 06:59 PM
lunatic14r's Avatar
remove the engine mount bolt and jack the engine up a little
Old Jan 22, 2004 | 07:12 PM
joeal's Avatar
how hard is that to do??
Old Jan 22, 2004 | 07:19 PM
lunatic14r's Avatar
not that hard just tight to get at the engine will only move a little but it enough to get it in ( what problem are you having)
Old Jan 22, 2004 | 07:30 PM
joeal's Avatar
well i stick it in, adn it hits the reed valve, or either hits brake lines down at the bottom. Once it was hitting the wires going to the fuse box. Did you try to stick it in from the top or from underneath the truck? Also did you just stick it straight in, or was it turned sideways goin in and and then you twisted it the right way? thanks!
Old Jan 22, 2004 | 09:51 PM
AgRunner06's Avatar
Post
This is why we have a Tech Section here at Yotatech.
3.slow Header Installation
Old Jan 23, 2004 | 04:00 AM
joeal's Avatar
yes, i have read that article many times, and no where does it specifically say how he got the passenger side header in
Old Jan 23, 2004 | 04:43 AM
MTL_4runner's Avatar
Not sure if you saw this thread or not.
http://www.4x4wire.com/toyota/tech/downeyheaders/
Old Jan 23, 2004 | 07:30 AM
Churnd's Avatar
I fit it in there without removing/moving anything. Just takes patience and the right angle. If you have to, you can start removing stuff that gets in your way. Take the reed valve off the engine if necessary. You will have to take it off the engine eventually to mount it on the header.
RatOmeter
Oct 22, 2015 03:17 PM
Sep 4, 2015 09:27 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
clok
Aug 1, 2015 09:42 PM
Coreyr384
Jul 10, 2015 11:13 AM
