engine questions
Old Dec 9, 2004 | 02:09 AM
natedawgg94's Avatar
Question engine questions
hey i've got a 87' 4wd with carb 22r. i'm in the process of rebuilding and i've notice on my center cam journal it has some pitting and grooves. question is is there any way to build this back to factory spec? if so how? also i've has some surface rust in spots on my crank anyone recommend using superfine steel wool to repolish? or is there something better?
Old Dec 9, 2004 | 05:07 AM
MTL_4runner's Avatar
On the cam you would need to have a machine shop weld it back up and regrind it (could be some $$$)
I would use some 600 wet/dry paper on the crank rust spots before assembly
Old Dec 9, 2004 | 05:16 AM
Question
Sorry I meant pitting and scratches on the center bearing for the cam on the head. I'm going buy new cam which would you refer for rode driving and some mudding on occasions with 34x9.5x15 superswampers? Do you think machine shop could alum. weld the center of the head and the cap then install all 3 caps and line bore them to match new cam?
Old Dec 9, 2004 | 10:16 AM
kyle_22r's Avatar
i think the machine shop can line bore them. i think there's also cam bearing inserts(saw them on autozone's website?) but i'm not sure how those work because the cam rides directly on the head!
you'll probably want an RV cam like an engnbldr 261C
Old Dec 9, 2004 | 10:24 AM
No cam bearing cam sits directly on head from factory on this year model I know for sure not sure on others. Is line boring and putting bearing in an option or would i just come out cheaper buying new head? What's difference in stock and a 261c? torque or power?
Old Dec 9, 2004 | 12:36 PM
kyle_22r's Avatar
it'll move your torque curve down a little lower and maybe give you some more horsepower. makes it easier to spin thos big tires
Old Dec 21, 2010 | 06:27 PM
cba321k's Avatar
i have the same problems with my head. my machine shop said there was nothing they could do. anybody know where to get a good used head or a good price on a new one
Old Dec 22, 2010 | 01:47 AM
Resto-noob's Avatar
Fill in your location and I'm sure someone will be able to help you further.
bigjstang
Jun 2, 2025 03:56 PM
kazuya2416
Apr 5, 2024 02:17 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Cplmike
Jul 8, 2015 08:47 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
