Daytime running lights??
Old Jan 1, 2004 | 02:28 PM
wyldrs's Avatar
Is there a fuse or wire to disconnect the daytime running lights on a 2nd gen 4runner??
Old Jan 1, 2004 | 02:45 PM
Andrey's Avatar
Here ya go:
https://www.yotatech.com/~corey/tech..._drl/ducky.htm
-- Andrey
Old Jan 1, 2004 | 07:04 PM
wyldrs's Avatar
So it should work the same for the 2nd gen runner??
Old Jan 1, 2004 | 09:24 PM
pfdaxe's Avatar
Since when did 2nd gens have DRLs??
Old Jan 1, 2004 | 09:34 PM
doink's Avatar
my thoughts exactly
Old Jan 1, 2004 | 09:57 PM
Mossback74's Avatar
My DRLs are on a switch (usually off). for 2nd gen's, the switch is mounted at the end of the turn signal switch. Twist the end and the DRLs will be off/on
Old Jan 2, 2004 | 07:32 AM
pfdaxe's Avatar
Mossback74:
If you have a 98, then that's a 3rd gen not a 2nd unless I'm missing something here. As far as I know, DRLs didn't come on 4 Runners 'til '00. I think maybe Canada had them sooner???
Old Jan 2, 2004 | 08:22 AM
rwmorrisonjr's Avatar
From: Home: Aurora, CO; Work: The People's Republic of Denver
The 3rd Gens have the auto headlamp off feature if you leave the lights on, they turn off when you open the door and the engine is off. Kind of a psuedo-DRL setup. Do your dash lights go on & off and the clock dim when the DRL's come on?
Canadian cars have been required to have DRL's since 1990.
Old Jan 4, 2004 | 10:33 PM
Mossback74's Avatar
Mossback74:
The 2nd gen comment was my attempt at a joke, The switch I was refering to was the headlight switch . As far as my rig goes, the previous owner had DRL's installed with a switch so they can be disabled.
When the DRL's come on the dash lights do not come on and the clock does not dim.
I had a 2nd gen for a time, check the sig :cry:
ashersullivan88yota
Jan 18, 2022 05:37 PM
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
Johntom240
7
Jul 13, 2015 12:18 AM
madxman21
Jul 9, 2015 10:26 AM
