Dash/Taillight lighting problem
Old Jan 8, 2007 | 07:19 PM
mikelj's Avatar
I have a 98 4runner 2WD and today for some reason my instrument cluster lights, my AC/hazard/defrost lights all went out along with my taillights, all at once. I checked the fuse, its cool, but its really strange that they all should go out at once. I checked the usual suspects the dimmer, the fuse, but its odd everything would go out at once. I have tons of electronic additions, but nothing recently and other than an aftermarket CD player, nothing really tying into the main electrical system. It just happened today, and I can't find my Chilton, but I just figured someone may know of a wire harness/relay/fuse that all this stuff runs through before I killed myself tracing it. I have to put my 791VX alarm in so I guess it would be a good time, but still.
BTW the brake lights work.
Thanks for any help.
Old Jan 8, 2007 | 07:34 PM
Griffeycom's Avatar
When my dash lights went out, it was one of the fuses under the hood that was blown. I can't recall which it was though, recheck those and see if you find a bad one. A loose wire caused mine to short and blow the fuse.
I don't think my taillights blew with those too though...
Old Jan 8, 2007 | 07:43 PM
DeathCougar's Avatar
If your fuse is Ok, its the head light switch. That turns on all the running and dash lights. I sell every switch I get because of that very problem.
Old Jan 8, 2007 | 08:01 PM
mikelj's Avatar
Where is the switch? Its an inline switch, right, not the physical switch controlled on the steering column?
Old Jan 9, 2007 | 05:22 PM
nono, the actual on/off switch mounted on the steering column.
Old Jan 9, 2007 | 05:33 PM
toyotaoffroad91's Avatar
i would test the fuse if you didn's sometimes just looking at it isnt enuf
Old Jan 9, 2007 | 08:46 PM
mikelj's Avatar
I found the problem fellas, it was a fuse, but it was a strange location. It was all the way in the back of the fuse box under the hood. I can't read the label but yeah. thanks for all the help. Next time I'll pull out ALL the fuses first.
Thanks again.
Old Feb 5, 2007 | 09:40 AM
fornesto's Avatar
I'm having the identical problem with my 1996 4Runner with 205K miles. I have no dash lights, no tail lights. Brake lights work fine and headlights work fine. I also realized I don't have the ding, ding sound when I leave my headlights on. I've checked the No. 8 10A fuse and the new fuses keeps snapping as soon as I hit the headlight switch.
Death Cougar and others, where would you start with this?
Old Feb 6, 2007 | 01:08 PM
fornesto's Avatar
Do you remember which loose wire? I've got a small window before it rains to get my lights going today and would rather start at a likely spot. Some vehicles have inherent wires-in-bad-locations.
Anybody else, please chime in.
Old Feb 10, 2007 | 02:10 PM
Beartracker's Avatar
Thanks again.
Just a suggestion but I would mark or name that fuse and leave a note about it in your Manual or just a note in the glove box encase it happens again on down the road. Glad you found it and that it was a minor problem. I hate electronic problems!!. But thats because I'm really stupid about any wiring:hillbilly: Mike
Old Feb 10, 2007 | 02:19 PM
Godzilla's Avatar
that fuse you blew was the 10amp TAIL fuse...why do i know this...i just blew mine today.haha
ashersullivan88yota
Jan 18, 2022 05:37 PM
Sleaker
Aug 26, 2020 06:03 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
rushw
Jul 18, 2015 01:46 PM
madxman21
Jul 9, 2015 10:26 AM
