Dash light questions ???
Old Aug 24, 2005 | 04:15 AM
Beartracker's Avatar
Did a search on this and there is a ton of crap but nothing addressing my problem that I could see. Yesterday I noticed that the right one third of my gauges are barely lit up like the gas gauge and the right side of the speedo. The left two thirds are great.
If it's a burnt out bulb where can I buy them without driving to my Toyota dealer who is 55 miles away? These are the white faced gauges with the red lights and I don't want to change them with any LED lights or anything that I would have to solider leads to, I'm really lousy when it comes to that stuff Brighter would be fine as long as I just plug them in.
Next question is does anyone know what I have to remove to get to the bulbs and how I do it? Never had my dash apart. Thanks for any help you may have, Mike
Old Aug 24, 2005 | 08:07 AM
Come of folks. How about a little help here, Mike
Old Aug 24, 2005 | 10:49 AM
2001Millrunner's Avatar
refer to tech section-how to's. Butnut shows you how~
http://www.4runners.org/articles/wfg/
I'd assume tacomas dashes are almost identical if not same as 4runners
there should be little bulbs that you can just twist out. Might be a little bigger than the HVAC lights.
Old Aug 24, 2005 | 10:57 AM
97Limited's Avatar
Hey Beartracker
If your Tacoma is the same as my Runner then there are 3 (194) bulbs (like the ones in your front corner lights) that light up your speedo!!! just pull your speedo out and un-plug all the connectors theres 3 or 4, I haven't done it in a while!! The bulb sockets just twist 90 degrees then they slide right out, then just slide the green silicon bulb cover over the new bulb, and put everything back!!
Good luck!!
Old Aug 24, 2005 | 10:58 AM
Thanks Ray, Mike
Old Aug 24, 2005 | 11:01 AM
Thanks Limited. Mine are the red lights so I hope they have a red rubber on them. Where did you buy your 194 bulbs? Mike
Old Aug 24, 2005 | 11:05 AM
97Limited's Avatar
Your Welcome Beartracker, Well I put Blue 194 LED bulbs in my Speedo!! the regular bulbs you can get then pretty much anywhere they sell automotive light bulbs!! and LED style ones over the net, which come in every color!! Good luck
Old Aug 24, 2005 | 11:16 AM
97Limited's Avatar
Hey Mike;
There is a great write-up in Tech Write-ups under Maintenance & Repair/Dash Removal
https://www.yotatech.com/~corey/tech...utnut_dash.htm
I hope this will help you a bit! Jesse
Old Aug 24, 2005 | 04:21 PM
Got it done! It took me about 1 hour. A couple things that are different from the 4- runner write up is that I also had to remove the center dash piece, the one over the radio and heat/air controls and I also had some trouble taking duct work for the air and heat off on the left side. It all went back togeather real well.
Replaced all 3 lights while I had it apart. The 194 bulbs were .48 cents each at Auto Parts in town. Toyota wants around $4.75 each ,Lol
Thanks again guys for all your help, Mike
Old Aug 25, 2005 | 08:16 AM
97Limited's Avatar
Hey Mike:
Good to hear everything went well!! Sorry to here about the difference with the Taco. I haven't done any work on one yet!!
Old Aug 25, 2005 | 09:03 AM
Originally Posted by 97Limited
Hey Mike:
You haven't worked on a real Toyota until you worked on a Tacoma,
There was no problems and everything is the same except the center dash and the duct/Vent.
The only thing that really made me feel stupid was after I had it all back togeather and turned on the lights none of the dash lights worked.I checked it before I put it all back and it was fine. Checked the fuses and was just about ready to tear all down again when I looked at the dimmer switch and realized that I turned all the way down when I put the knob back on
Old Aug 25, 2005 | 09:16 AM
97Limited's Avatar
Hey Mike;
Well i haven't worked on a Taco cause my family is all 4Runners
I had an 87 4Runner,
I have a 97 4Runner now,
Parents have a 94 4Runner,
Uncle has a 89 4Runner.
That dimmer switch gets me everytime too!! LOL
ashersullivan88yota
Jan 18, 2022 05:37 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
Johntom240
7
Jul 13, 2015 12:18 AM
