cutting a hole in stock bumper
Old Sep 23, 2003 | 11:14 PM
apc's Avatar
apc
What would you say is the best method to cut a 1-3/4" hole into a stock toyota rear bumper? I am planning to put a 7 pin trailer connector into there.
Would it be possible with a sawz-all? Do they make hole saws to cut through chrome steel?
Thanks.
Old Sep 24, 2003 | 03:51 AM
jacksonpt's Avatar
Senior Member
Dremmel.
Old Sep 24, 2003 | 04:16 AM
waskillywabbit's Avatar
Re: cutting a hole in stock bumper
Thanks.
Why not just mount the connection to the hitch instead of cutting a hole in the bumper?
Use a drill to start your hole then get a jig with a metal cutting blade.
Brian
Old Sep 24, 2003 | 04:20 AM
hillbilly's Avatar
Thanks.
Yes. Hole saw. Make sure you use a small standard drill bit to drill out a small pilot hole first, then use the hole saw to finish.
Old Sep 24, 2003 | 04:46 AM
jacksonpt's Avatar
Senior Member
Sorry... I don't know why, but I was thinking you wanted a square hole. If you want a round hole, a hole saw is definitely the way to go.
Old Sep 24, 2003 | 09:04 AM
Sac State's Avatar
You can clean the hole up with a Dremel using a grinder attachment. Besides a Sawzall, the Dremel is a tool that is very useful. Too bad there is not a battery operated Dremel.
Old Sep 24, 2003 | 10:01 AM
hillbilly's Avatar
Ahhh... but there IS! Check out your nearest Lowe's. I just saw one there a day or two ago....
Old Sep 24, 2003 | 01:52 PM
Erich_870's Avatar
He's right, there are battery powered dremils. I have one, and it works well, but it doesn't spin as fast as the corded and it doesn't have as much torqe. I actually have an older one, so there is a chance they have beefed it up, but I want a corded one now
young buck
18
Aug 27, 2018 02:40 PM
lledwod
Aug 30, 2016 01:03 PM
nick9455649
Sep 11, 2015 05:10 PM
coffey50
Jul 28, 2015 10:55 AM
crashburnoveride
Jul 10, 2015 06:39 AM
