compression tester
Old Jul 26, 2004 | 06:04 PM
2wd1stgen's Avatar
compression tester
I want to buy a relatively inexpensive compression tester. What do you guys recommend? I am seeing some good deals on ebay. Any brands to stay away from?
Old Jul 26, 2004 | 06:06 PM
Yoter's Avatar
Guest
I use to have a Matco CT and it worked great. Matco, SnapOn, Mac, Craftsman should be okay.
Old Jul 26, 2004 | 11:02 PM
Nolan's Avatar
while the topic is out there, what all is involved in the process? Can the novice mechanic do this?
Old Jul 26, 2004 | 11:44 PM
superjoe83's Avatar
i might add that a cylinder leak down tester is also a good tool to have
Nolan, its as easy as changing your spark plugs
Old Jul 27, 2004 | 09:07 PM
Nolan's Avatar
can you explain a little more in depth? Just a quick summary of the process.
Old Jul 27, 2004 | 09:15 PM
TOYJZX100's Avatar
i believe you plug in the compression tester in place of the spark plug in the cylinder you are testing, then you crank the engine a bit. the guage should now say how much psi the compression is in that cylinder. i did it on an integra in school.
Old Jul 27, 2004 | 09:45 PM
wrx2yota's Avatar
make sure you pull the fuse for the fuel pump. You want to make sure you have the throttle all the way open as well.
other than, pretty simple. Most autoparts stores, especially NAPA will have the basic gauge compression testers. There are electronic ones, but they are a waste of money.
Old Jul 27, 2004 | 10:00 PM
TOYJZX100's Avatar
wrx2yota, do you know if it matters where the piston is at b4 testing the compression?
Old Jul 27, 2004 | 10:02 PM
wrx2yota's Avatar
nope.. piston location doesn't matter.
You want to crank it for about 10 seconds to get a good reading.
Old Jul 27, 2004 | 10:49 PM
superjoe83's Avatar
and you may want to put a low amp battery charger on it while your testing, because after you crank it for 10 sec a few times the engine will start to turn slower because your loading the battery pretty good, when it turns slower you will not get accurate readings because the piston is moving slower so the air in the cylinder has more time to leak by the rings, thus giving you lower results
Old Jul 28, 2004 | 01:43 AM
2wd1stgen's Avatar
What do you think of mityvac name brand compression tester?
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
Kamaloha
Oct 16, 2015 05:13 PM
alexcarey
Oct 14, 2015 06:05 PM
dzldust
7
Oct 6, 2015 05:39 AM
