Clutch Reserivor Tank Leaking into Cab
My Clutch Reserivor is leaking into to my 4runner. the leak appears to be coming from inside the cab. It leaks fluid all the way down the clutch pedal. It is a slow leak. But i want to get it fixed. Any one know how to fix this?? please help me
[QUOTE=toyota884runner]My Clutch Reserivor is leaking into to my 4runner. the leak appears to be coming from inside the cab. It leaks fluid all the way down the clutch pedal. It is a slow leak. But i want to get it fixed. Any one know how to fix this?? please help me[/QUOTE
Youre master cylinder is going bad. it will need to be replaced soon. There is realy nothing else you can do. I have tried rebuilding mine, but had no luck.(it went bad within a month) :pat: Replacing it with a new one was my best option. Its not a very hard fix it just takes a bit of patience to bleed the system. Hope this helps.
It's a good possiblilty your clutch master cylinder needs to be replaced.
I had the same thing happen with my 84 Camry. My carpet is permanently stained because of it.
It turned out that I needed to replace the clutch master cylinder-it was going bad. I tried to rebuild the original, but it didn't work. I ended up buying a new one from the dealership. It was a very easy job to do on my car. I would think it should be fairly simple for a 4Runner too.
Originally Posted by toyota884runner
man you got burned. you can get the exact same thing from marlin crawelers for $29 plus shipping. I bet the brake booster cost you $263.71.
Actually the dealer wants $1100 for a new booster. Needless to say I got a booster and master cylinder off of a '94 for $125 that I think I can make work.
Nak
Road Bull
Oct 10, 2015 04:55 PM
Avenged
Jul 9, 2015 07:55 AM
skoti89
Jul 8, 2015 12:05 AM
