A/C compressor stuck?
Old Apr 26, 2004 | 06:11 AM
Sbrut95's Avatar
Okay, So while I was under my truck yesterday I noticed that I didnt have a AC belt anymore. That would explain the loss of cold air. :pat:
So I went out and got a new one and put it back on. But when I started up the engine and pushed the a/c button, the belt squeeked a little and the engine stalled. So I looked down at the compressor and it looks like my clutch is good, but the compressor or the pulley is not working. It just siezes up and wont spin. Is it time for a new compressor or could there be something wrong with the pulley?
One more thing, if anybody has time. Twice now, when I first go to crank the engine over, it doesnt do anything. So I turn the key back and try again, and it fires right up. Anybody got any suggestions? Alternator maybe? Thanks.
Old Apr 26, 2004 | 08:33 AM
MTL_4runner's Avatar
Put a wrench on the pulley center and see if it turns.
If you have a tough time turing it or not at all, then the compressor is toast.
Old Apr 26, 2004 | 08:38 AM
Sbrut95's Avatar
Well, I loosened the nut that is on the pulley the other day. But I dont know if the pulley was spinning freely or not. Its kinda hard with the belt on it. Maybe IM not getting what youre saying??
Old Apr 26, 2004 | 12:06 PM
toy283's Avatar
With the engine and AC both off, you should be able to turn the compressor by the center bolt. The belt should not turn becasue the drive clutch is disengaged (AC off). I'd be willing to bet that the lost belt is a symptom, not a cause. Your compressor siezed, toasting the previous belt. BTDT.
Old Apr 28, 2004 | 07:05 AM
madmaniac's Avatar
i had the same symtoms with the car not starting. it will get worse and worse. sometimes it would take like 20 tries to start my car. it ended up being the starter.
Old Apr 28, 2004 | 07:57 AM
Robinhood150's Avatar
Replace your starter contacts. There's an excellent write up in the tech section.
justdifferentials
14
Jun 11, 2017 08:36 PM
Ronnyboy
Feb 11, 2016 05:57 PM
coryc85
Dec 5, 2015 08:42 AM
Ktm526
Oct 7, 2015 05:14 AM
Tacoma1313
Sep 8, 2015 01:27 PM
