Can you test an LSD
Old Jan 14, 2003 | 02:51 PM
kerrs's Avatar
Can you test an LSD
My truck is fitted with LSD's as standard.
How do you know if they are workin' ?
In MUD only one wheel spins
Help, Kerr
Old Jan 14, 2003 | 04:17 PM
Dr. Zhivago's Avatar
Away
You can try testing an LSD by applying moderate brake pressure when you have a slipping wheel to see if it will xfer power to the wheel with the most traction. That's how a LSD should work.
Hope this helps.
Dr. Z
Old Jan 14, 2003 | 04:31 PM
WATRD's Avatar
It's going to depend upon which type of limited slip you have. If it's one of the clutch type "lockers", then that is a bad symptom. If it is a viscous coupling or a Torsen type, then what you are seeing is expected behavior. Torsen stands for "Torque Sensing" and if one wheel completely loses traction, then the other can't be made to spin. That is why you more commonly see selectable lockers, spools and the clutch type limited slip in off road vehicles.
From the "How stuff works" website;
However, if one set of wheels loses traction completely, the Torsen differential will be unable to supply any torque to the other set of wheels. The bias ratio determines how much torque can be transferred, and five times zero is zero.
A quick primer on differentials is located at; http://www.howstuffworks.com/differential.htm
At best, a differential can supply equal torque to both sides, that is a locker. At worst, all the torque goes to the wheel with the least traction, that is an open diff. All limited slip systems are somewhere in between.
-edited to remove an incorrect statement- Thanks for keeping me honest HBoss!
Old Jan 14, 2003 | 08:00 PM
HBoss's Avatar
As per Rob, it depends on the type of LSD you have. Do you know what type of LSD you have, by chance?
As far as I know (and as per howstuffworks.com) you can have greater than equal torque to each side with Torsen diffs and the way they bind. That's one of the reasons that Torsen differentials are considered superior.
Old Jan 14, 2003 | 08:08 PM
WATRD's Avatar
Crap! You are entirely correct. I had convinced myself that that the bias was the other way, with the traction wheel getting 1/5 of the torque the slipping wheel was getting.
Doh!
I will edit that post so I don't leave the incorrect information in the archives.
Old Jan 14, 2003 | 08:15 PM
HBoss's Avatar
lol. No prob Rob. I know you'd do the same for me. Even if you do root for the Seahawks.
Old Jan 14, 2003 | 08:24 PM
WATRD's Avatar
I am telling you Man, take all your money, your truck title and your mortgage and put it on the Seachickens to take the Superbowl next year!
Then retire in the lap of luxury to that ocean front property in Arizona you bought and enjoy your beautiful view of the Brooklyn Bridge.
That will give you lots of time to install this Pringle's can in your engine for a 300 horsepower gain and 60 miles to the gallon.
You'll thank me for this tip, someday...
Old Jan 14, 2003 | 08:37 PM
HBoss's Avatar
Pringle's can...300 hp you say...sounds like a steal...I'll take two.
Old Jan 15, 2003 | 06:01 AM
kerrs's Avatar
I am trying to find out what type of LSD it is.
It doesn't even mention an LSD in the owners books.
But there is a sticker on the diff "Use LSD oil only"
I'll keep you posted
Thanks for all the help
Kerr
Old Jan 15, 2003 | 06:45 PM
tomus1000's Avatar
I tested LSD a few times back in college. It seemed to work pretty good.
LOOK AT ALL THE PRETTY COLORS...
Old Jan 15, 2003 | 07:36 PM
WATRD's Avatar
hahahhahaha I thought the same thing when I first saw the post...
Weren't those the days... If I NEVER see my walls breath or my carpet grow again, it will be too soon...
justdifferentials
14
Jun 11, 2017 08:36 PM
Obmi
Oct 30, 2015 04:27 PM
accuracy
Sep 20, 2015 07:44 PM
Boomer8404
Sep 10, 2015 09:01 AM
justdifferentials
Sep 5, 2015 06:52 PM
