best mods
Old Aug 3, 2005 | 08:22 AM
Mobcore911's Avatar
best mods
Heading to school in Colorado in less than 2 weeks...whats the best way to spend 1,000 bucks on a nearly stock 84 4x4 pickup?
and $1000 for at school doesn't count hahaha
Old Aug 3, 2005 | 08:26 AM
RED 85's Avatar
Depends on what you want to do performance or wheeling ability?
B
Old Aug 3, 2005 | 08:36 AM
94x4's Avatar
Guest
ISR mod, exhaust, Ignition system upgrade, BJ spacers, (*edit*) shackles, or leaf springs, (*edit*) shocks and ceramic brakes..., although not necessarily in that order..., which will give you a little bit of both worlds (performance and offroadability) and get your foot in the front door to go further in either direction.
Old Aug 3, 2005 | 08:53 AM
deathrunner's Avatar
First off are you gonna be keeping the 84? I read your other post about gettinga n 89 runner....
anyway if you're gonna mod the 84, I would get:
A header, and a rear locker, that should put you back about 6-700, then you might as well get a front locker.....
so header and front and rear lockers....that's my vote
Old Aug 3, 2005 | 09:12 AM
Flamedx4's Avatar
something like this:
http://cgi.ebay.com/ebaymotors/79-85...89978161QQrdZ1
and set of 32x11.50s would use up your 1000. But budget to add a rear traction aid of some sort and you're all set.
Old Aug 3, 2005 | 09:14 AM
Bagger's Avatar
For college in Colorado, you might want to get some snow tires and make sure your heater and radiator are up to snuff.
I would also invest in some recovery gear, ie straps, shackles, hilift, shovel, etc.
Then some CO trails books and a Chilton's manual ( since you won't be able to afford a shop to work on your truck for the next 4 years).
Lastly I would invest in some lockable storage boxes and perhaps an alarm system to keep whatever you spend your grand on from being stolen.
PS - a valuable piece of advice re college. Don't sign up for any 8am classes or classes that meet on Fridays after 1pm. You'll soon figure out why... Good luck dood!
Old Aug 3, 2005 | 09:16 AM
Silver_Truck's Avatar
I second the lift, pick up some used 33s for around 400 then spend the remaining couple hundred on a repair manual, recovery gear and even an ebay header
Old Aug 3, 2005 | 09:19 AM
Flamedx4's Avatar
Originally Posted by 94x4
ISR mod, exhaust, Ignition system upgrade, BJ spacers, coils or coil spring spacers, shocks and ceramic brakes..., although not necessarily in that order..., which will give you a little bit of both worlds (performance and offroadability) and get your foot in the front door to go further in either direction.
Would be interesting to see how ball joint spacers and coil springs/spacers would improve an '84....
Old Aug 3, 2005 | 09:29 AM
Mobcore911's Avatar
most of these mods applicable to an 89 runner? see other post (84 vs. 89)
Old Aug 3, 2005 | 09:30 AM
braverex's Avatar
I SECOND and THIRD that!!! I took a year of physics at 8am and it really sucked!
Old Aug 3, 2005 | 09:36 AM
geneius's Avatar
- Lift
- Tires (my BFG AT 33s were $125/piece @ discounttire, great for the snow, trail, rain...), - Tint
- ISR
- Breather Mod (does this apply to pickups as well?)
- K&N filter (crutchfield.com ~$35)
- Driving/Fog lights (advanceauto parts has the hella 500 for $54.88)
- Coolant/Brake/Tranny flushes
- A new battery?
Old Aug 3, 2005 | 09:46 AM
Mobcore911's Avatar
whats an ISR?
Old Aug 3, 2005 | 09:54 AM
geneius's Avatar
check this out:
https://www.yotatech.com/~corey/tech/blu_intake/blu.htm
Old Aug 3, 2005 | 10:27 AM
jimbo74's Avatar
84 4x4... is that a 22re or a 22r? the best power cheap mod i did was the giant air cleaner mod... less than $10 ... you need a m6x1 threaded rod, a wingnut and a locknut.... will also need to extent the breather hose to the top or cap it off on the cover and install a lce or similar breather to it...
stock next to the giant air cleaner
after:
Old Aug 3, 2005 | 10:37 AM
rngrchad's Avatar
get any type of mud terrain, and buy a rear locker....if it's and 84 lift is a minor issue...33's should fit stock w/ slight rubbing.
Old Aug 3, 2005 | 11:03 AM
99_Runner's Avatar
What college are you going to be going to. I am in Westminster, and I know there are quite a few other guys on here and we cover the entire Denver/Metro area and some other major cities. What ever you get, get some good all season tires, as Swampers suck on icy roads.
Also, let us know where you are going to school and I'm sure some of us would volunteer our garages and our help for any mods that you need help with.
Old Aug 3, 2005 | 11:07 AM
Intrepid's Avatar
Get a rear locker,some mud tires, and a CB radio for the love of god! The CB is probably the best and most used item I bought for my truck.
Old Aug 3, 2005 | 12:40 PM
94x4's Avatar
Guest
o'kay, o'kay..., should have said "shackles" or "leaf springs".
Old Aug 3, 2005 | 12:46 PM
94x4's Avatar
Guest
Originally Posted by Mobcore911
whats an ISR?
"ISR" stands for Iintake Silencer Removal and may or may not apply to your ride, depending on whether or not you've a 'Runner or a truck.
TheBFA
Feb 15, 2020 06:55 AM
punks_is_4x4
May 31, 2016 06:03 AM
voiddweller
53
Feb 1, 2016 05:46 AM
oldblue
Sep 28, 2015 04:07 PM
Project90
Sep 24, 2015 11:40 PM
