Auto up/down windows
Old Nov 11, 2011 | 12:30 PM
Jefe23's Avatar
Diagram14 - I ran a car stereo/alarm install shop for 5 years and you can add one-touch operation in both directions to any power window system with the addition of a couple window modules. They aren't cheap and you would need one module per pair of windows. The downside is that in order to add to other windows that aren't one-touch, you would have to run wires into each door independently. Very doable and pretty straight forward but time consuming nonetheless.
I haven't done any research on the swap to a switch from a newer vehicle but the one-touch operation comes from relays and limit switches and not the motors themselves.
I added a cheap mod to the sunroof in my '98 located here if you're interested...
https://www.yotatech.com/forums/f2/9...on-mod-216675/
Old Nov 11, 2011 | 03:20 PM
Nelsonmd's Avatar
Originally Posted by X2and4X
Yeah and that stopping 2/3 closed is annoying. Why?
Originally Posted by drguitarum2005
methinks its a safety feature so you cant just press close and pay attention to someone else while your hair or cat's head is stuck in the window path. the stopping 2/3 of the way is the same concept so you dont hold your finer on it not paying attention while doing something else, for the same reason
You may be onto something. But I say let the same principles apply to the moon roof as the side windows. give it pinch protection. as for the hair well the side windows dont care why should the moon roof.
So I'm quoting old threads, but it is really easy to defeat the mid-point stop. See how I did it here:
http://www.toyota-4runner.org/3rd-ge...tml#post771534
My auto-up mods are not working right now, but if I ever get some more time to work on it, I will fix them. I plan on just making a simple circuit using a couple LM555 chips for the auto up.
Jun 1, 2021 01:51 PM
okamikai
Apr 30, 2018 10:19 PM
britishdudes2dr
Jul 25, 2015 06:47 AM
RustBucket
Jul 24, 2015 04:46 AM
icentropy
Jul 14, 2015 10:23 AM
