ashtray opens by itself
Old Dec 14, 2005 | 10:33 AM
FORANA's Avatar
Hi guys. Somehow something broke I am assuming and my ashtray doesn't stay shut, it slowly opens itself. I looked and examined everything and I can't figure it out. Anyone? HELP!!
Old Dec 14, 2005 | 11:18 AM
Lt. Dan's Avatar
The only suggestion I can give you is to have a look at someone else's ass-tray, with their permission of course, and see how it is assembled.
Old Dec 14, 2005 | 11:19 AM
THE04Runner's Avatar
Is there a clip or lock or something that keeps it shut?
Old Dec 14, 2005 | 11:22 AM
Godzilla's Avatar
A few things to look at would be the tightness of the screws that hold in the ashtray guide (remove ashtray to see) and the springs on the ashtray itself. There is the metal top and the plastic bottom that are connected and can be removed from the ashtray guide.
Old Dec 14, 2005 | 11:31 AM
Intrepid's Avatar
My Tacoma had this issue, there is a metal clip that you have to push down to remove the ashtray fully, I bent mine back and up a little and the problem stopped. Give that a try.
Old Dec 14, 2005 | 11:44 AM
garrett1478's Avatar
mine did that when i got it. i dont know how yours is acting, but mine would just slide out during driving. not the entire thing, just the tray. i removed it and put a cb there...works for me
Old Dec 14, 2005 | 12:03 PM
callmej75's Avatar
I would recommend an exorcism....
Old Dec 14, 2005 | 05:29 PM
Tacoma Dude's Avatar
I might have an extra one lying around somewhere... I'll see if I can find it.
Old Dec 15, 2005 | 11:44 AM
X-AWDriver's Avatar
Mine only does it once it get too much change in it.
Old Dec 15, 2005 | 01:03 PM
Jboy's Avatar
Same here. I try to keep it empty. Best solution is if you don`t smoke take it out.
Old Dec 15, 2005 | 01:22 PM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
Awwwww! You beat me to it!!!!
Old Dec 15, 2005 | 01:28 PM
cubuff4runner's Avatar
I have mine full of change and it never opens. The trick is that there is a litle metal clip that holds it in place, but there isn't a big enough bump in the plastic for the clip to hold. The fix is find the exact spot where the clip sits when the tray is closed, bend the clip slightly so it gets good pressure on the plastic slider. Then get a dremel or something similar and grind a groove in the plastic for the clip to sit in and grab better.... Problem Solved
Old Dec 15, 2005 | 01:50 PM
callmej75's Avatar
Old Dec 15, 2005 | 07:47 PM
fondigley's Avatar
hell we got 4 tacomas in my family and I think all of their trays slowly slide out. I just always shut it when I see mine creeping open.
Old Dec 15, 2005 | 08:46 PM
HUTCHSTACO's Avatar
mine do it too, never knew it was such a big issue, i will have to look into fixing it now.
Old Dec 15, 2005 | 10:13 PM
FORANA's Avatar
Thanks for all the help guys. I will try bending the clip first. Then the dremel thing. I used tape the other day. Worked well cept the inconvienence of it.
Old Dec 16, 2005 | 03:27 PM
Chapman88SR5's Avatar
http://cgi.ebay.com/ebaymotors/TOYOT...21468094QQrdZ1
hurry it ends soon
Old Dec 17, 2005 | 02:46 AM
surf4runner's Avatar
mine has plastic guides that it slides on and they were broken. reglued and now it stays closed.
Old Dec 17, 2005 | 02:43 PM
2001Millrunner's Avatar
is spring mechanism still functional? it's supposed to keep enough tension to kept closed...
kawazx636
Oct 6, 2021 03:03 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
dbollier123
Sep 29, 2015 05:23 PM
PNW94Runner
Sep 29, 2015 02:55 PM
