Old Feb 9, 2016, 10:04 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
anyone have sound system in the 4runner?
Old Mar 17, 2009 | 11:39 PM
  #141
4rx's Avatar
4rx
[QUOTE=SLYTLYSCRAMBLED;51091137]
Originally Posted by 4rx
That's a big sub box! Is the box 12 cubes after displacement? That does looks good, tho.
Chea, It is actually 14 cubes LOL!! I sorta miscalculated!! Or, I can Make it less, but like I said I'm debating on having first layer inside box or having both glued and on top of box... I just don't know... If I do, I think it should be better am I correct?? Then I will have 3.5 cubic per sub!!
Double layers on top of the box will be better. According to my winisd program, 12" port length is good. You're doing it the right way
Old Mar 18, 2009 | 09:29 AM
  #142
SLYTLYSCRAMBLED's Avatar
[quote=4rx;51091179]
Thanks.... Now the hard part of making the holes and port hole Here is a sorta dumb question, but never made a baffle top before... Am I suppose to glue the 2 together and then cut holes??? Just wondering if glue will mess up cut...
Old Mar 18, 2009 | 10:16 AM
  #143
toylocost's Avatar
From: Yotatech, because Pirate is too expensive. NorCal.
Hey could you get a picture of the box with you next to it or next to the truck. I cant quite put it into perspective. lol
Old Mar 18, 2009 | 02:06 PM
  #144
4rx's Avatar
4rx
The glue will not mess up cuts. You should get some 1 1/4" screws and do predrill on both layers then put glue on it. That's what I did to my back wall in my 4runner.
like this..
just give you some ideas..
Old Mar 18, 2009 | 02:20 PM
  #145
Ron's 85's Avatar
v8 chevy small block with dual exaust sounds really good in my 4runner!!!
Old Mar 22, 2009 | 09:22 AM
  #146
Here it is besides a 5 gallon paint bucket!!! LOL Still need to screw and glue the top down and either carpet or vynil it... Might have to make the RF logo and have it on the front and back of box...
Attached Thumbnails anyone have sound system in the 4runner?-image182.jpg   anyone have sound system in the 4runner?-image184.jpg   anyone have sound system in the 4runner?-image188.jpg
Old Mar 22, 2009 | 10:32 AM
  #147
toylocost's Avatar
Hey there are some empty holes in that box!
Old Mar 22, 2009 | 02:08 PM
  #148
4runner114's Avatar
kenwood head unit, 2 kicker cvr 12's, power acoustiks 2channel amp 540rms each channell, 2 bullett tweeters, 3 emenince 8's, 2 kicker 6's, 4 channel sony amp
Old Mar 22, 2009 | 05:52 PM
  #149
Chea... I need another amp.. The other 2 are still in my 4runner now... Just got through screwing and gluing the top down and debating on Vinyl or carpet...
Here's another pic...
Hey
4runner114, Nice set-up!!!
Attached Thumbnails anyone have sound system in the 4runner?-image191.jpg   anyone have sound system in the 4runner?-image192.jpg
Old Mar 23, 2009 | 12:06 AM
  #150
4rx's Avatar
4rx
SLYTLYSCRAMBLED, that's gonna slam hard!
Old Mar 23, 2009 | 12:18 PM
  #151
toylocost's Avatar
Hey
Hey just wondering what are your plans for power? As in what amps? Batteries? Caps? Alternator?
Old Mar 23, 2009 | 02:03 PM
  #152
4rx's Avatar
4rx
Caps are absolutey wasting money. I only have an interstate battery and stock alternator. The voltage measured at 11.5v at full tilt which isn't to bad for 2,500 watts.
I'd suggest upgrade 4 gauges wires, alternator to battery postive, battery negative to frame/chassis, and chassis to engine. You will notice huge difference. The alternator is the main of the electrical system. A high output alternator will be even better.
Old Mar 23, 2009 | 03:26 PM
  #153
Chea it is!!!
Old Mar 23, 2009 | 03:39 PM
  #154
Same stock alt, Rockford Fosgate T10001bd amp per pair, I have a cap but have to lose it and get Kenitic battery.... Just might for now use the 1 T10001bd amp I got, and wire it for 2 ohms stable and hook all 4 subs to it(750 watts) ... But still want to cover the box with sumfin Still don't know what to freakin do!! LOL!!
Oh and Chea 4rx... The 4 guage upgrade is what every1 calls THE BIG 3... It helps a whole lot!! I also still need to get holes for wires but What I want to do is just use a small bolt or all thread and drill a hole in box for that, and then use washers and nuts to hold it together on box. Then use the crimps with holes to connect wires to all thread... Did that make any sense?? LOL
Old Mar 23, 2009 | 04:46 PM
  #155
toylocost's Avatar
I'm runnin 4ga for power and ground. Headlights dim like crazy. (This is still in the Camry btw) If it does the same in the 4runner, I'm going to do the big 3 mod (search it) with 0/1ga. It may be oversized but how can you really be oversized when it comes to wire. Thats like saying its oversafe. lol
Old Mar 23, 2009 | 09:45 PM
  #156
bigtrucknwheels's Avatar
and you'll be over charged. of course, stereo systems regardless are always a no yield investment haha, so why not? the dimming of the headlights is more related to the battery and alternator than anything.
Paying extra money for the larger wire is sort of a waste, when you can spend the extra money on a heavier duty cycle battery and H.O. alternator and get much better results. That being said, make sure your wires aren't undersized. Upgrading the battery to chassis ground is ESSENTIAL if you plan on running any sizable load in these Toyota's. They only have an 8 gauge ground if I recall correctly.
Old Mar 23, 2009 | 09:55 PM
  #157
toylocost's Avatar
Its not very much more expensive than 4ga so why not. Not like I'm buying a mile either.
Another question. Is it bad for me to run it with the headlights dimming?
Old Mar 23, 2009 | 10:03 PM
  #158
nope. just annoying. and depending where you put your amp and how much you oversize your wire, the difference could be upwards of 15 dollars for materials alone. not to mention how much more expensive the fittings and terminals become haha. but I guess in the end that's really a negligible price difference to most. I just try to be thrifty at every corner haha...
Old Mar 23, 2009 | 10:49 PM
  #159
toylocost's Avatar
No, I meant I was doing the Big 3 mod with 0/1ga. I have 4ga on my amp. Yeah that would be expensive lol I think it takes about 20ft to do the runner.
Old Mar 25, 2009 | 05:39 PM
  #160
Chea, I have the 0 gauge wire to go to the back for my amp. I'm going to also upgrade my Big 3 to 0 also... I got my carpet for the box, but can't carpet it tonite... We have a tornado watch and it's raining like crazzzyyyy..... LOL!!!
