99 4runner. need to do wheel bearings,never done these kind before!
My girlfriends 4 runner has automatic hubs and i've never worked on a 4wd 4runner with automatic hubs is there any speciall tool i will need like a 54mm socket. Is it as straight forward as doing the wheel bearings on a straight axle with hubs. Are the bearings just sittin in the rotor like straight axle trucks with hubs? Just need an idea of whats in there before i go at it.
Both front wheels are making clickin sounds while driving down the road. the sound does not go away ever and the runner has about 110,000 miles on it and i dont think the bearings have ever been done.
Please a little advice goes a long way. Thanks.
Its not even close to the old style bearings. 54mm socket won't do anything. You will, however, need a 34mm socket to loosed the nut holding the axle in place.
The Tacomas and 3rd gen 4Runners with ADD (its not called auto hubs) used a sealed unit hub bearing. This needs to be pressed in and out.
Btw, i would also be looking at the CV's as the cause of the clicking.
http://www.ncttora.com/fsm/2000/Repa...20Hub/disa.pdf
this is for 2000 Taco, should be very close to 99 4Runner
jasonty
41
Dec 23, 2018 01:00 PM
Those are $400 EACH.
