cv axle without a snap ring?
Old Mar 2, 2009 | 07:34 AM
harpen123's Avatar
I just changed a driver side cv axle, I messed up the snap ring and made it too large. I figure I'd never get it off again if I tried using it this way. Has anyone ever ran one without a snap ring?
Old Mar 2, 2009 | 08:30 AM
raydouble's Avatar
I don't think you want to do that......
If your tire droops too much it will pull the cv right out of the diff.
Old Mar 2, 2009 | 09:04 AM
jmoore9982's Avatar
After reading your message I was able to ascertain your problem immediately. Being an Auburn grad you should have stuck to a mule or other suitable beast of burden with adequate intelligence to help you overcome that Auburn education. Roll Tide!!!
Seriously. Do not run without the snap ring. I just went through the same issue where a buddy of mine (Vols grad - go figure) "helped" me get the snap ring off. It's a $.99 item at the dealer and they probably won't have it in stock.
Old Mar 2, 2009 | 10:04 AM
harpen123's Avatar
Well I thought about it and there's not much travel in the front and I think the axle is long enough to keep it in.
Old Mar 2, 2009 | 11:02 AM
raydouble's Avatar
That isn't a good idea, most likely scenario is going to result in stripped splines or a broken axle.
Old Mar 2, 2009 | 05:11 PM
Bighead's Avatar
You might want to re-think that...Toyota put the snap ring there for a reason.
Old Mar 2, 2009 | 05:44 PM
Goin's Avatar
Just take the snap ring off the old axle and use it.
Old Mar 2, 2009 | 07:20 PM
TacoFitz's Avatar
I have and it worked ok for a little bit but it came out eventually. Fluid leaked out when it happend, so get one on there!
Old Mar 3, 2009 | 12:18 AM
jmoore9982's Avatar
The problem is that you don't have to pull the shaft all the way out to cause problems. If the wheel drops enough to pull the shaft out past the splines the you will cause damage. This is a $.99 part at the dealer and thy will have it in 2 days
Old Mar 4, 2009 | 09:39 PM
harpen123's Avatar
yeah this is a bad Idea just rechanged the cv because it leaked gear oil because it wasnt far enough in.
harpen123's Avatar
o well no harm no foul
polo451
13
Nov 20, 2016 07:49 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
snekysnake
Aug 13, 2015 02:46 AM
JimiJams
Aug 7, 2015 01:36 PM
accuracy
Aug 6, 2015 12:32 PM
