98 Toyota 4 Runner 4 cylinder
Old Aug 11, 2018 | 08:12 AM
Mystic98's Avatar
Engine light on and codes PO300, PO301 & PO304
Old Aug 11, 2018 | 10:53 AM
fierohink's Avatar
Those are codes for a miss. P0300 is random general miss, P0301 is cylinder #1 miss, P0304 is cylinder #4 miss.
I would start with the standard tube up items, spark plugs, fuel and air filter, wires, and test coils. The V6s are having age related problems with fuel injectors, I’m nit sure if the 4s are going to as well.
Old Aug 11, 2018 | 11:08 AM
Mystic98's Avatar
Thank you, I put new spark plug wires and spark plugs and air filter last summer, it ran good for awhile then the radiator started leaking at the top and spraying water right on the coils, I bought new plugs and wires but haven’t put them in yet. I do not know how to check the coils.
Old Aug 11, 2018 | 12:28 PM
fierohink's Avatar
This is the link to the V6 diagnostic for ignition coils, Im on my phone so digging for the 4cyl version is cumbersome.
http://www.teamtoyota4x4.org/archivi.../ignsy/ovi.pdf
Old Aug 11, 2018 | 12:47 PM
75w90mantraN's Avatar
Can test the coils if you have a spark tester that hooks up to the plug wire where it connects to the plug.
Some are adjustable to actually gauge how strong a spark.
Old Aug 12, 2018 | 07:56 AM
Mystic98's Avatar
Coils
Thank you, I will check it out.
Old Aug 16, 2018 | 07:53 PM
jreyes94's Avatar
I will assume you have the dual coil pack set up (each coil is for 2 cylinders). There are 3 different ignition set ups for the 3rz.
Using a multi meter, I tested the secondary coil resistance by unplugging the harness from the coils, as well as the spark plug wires, and sticking the leads in the positive/neg terminals- while the engine was cold.
It should read 9.0-15.4k-ohms. Someone please correct that if the ohms is not correct. (Edit: checked my Haynes manual)
Also, i had one injector start to go bad (@200k) and it caused a misfire code as well. Checking your injectors for steady pulse while the engine is running might be a good idea.
Old Aug 16, 2018 | 08:05 PM
Mystic98's Avatar
98 4Runnner
thank you for the info.
Charles4x4
Feb 25, 2020 03:05 PM
colleenbeetham
Jul 24, 2018 09:19 PM
4runners4ever
Jun 13, 2018 06:50 PM
Charles4x4
Jun 5, 2017 06:25 AM
rearviewmirror
7
Mar 26, 2005 09:31 AM
