98 4rnr Sound system replacement
Old Mar 25, 2006 | 04:04 AM
pablo88's Avatar
Question 98 4rnr Sound system replacement
Hi you all!! First of all I am sooo NOOB with this so please help me. Ok here is the story , the existing system is only cass& radio (with pwr ant) (part # 86120-0W060) I want to replace it with Radio& Cd system (OEM) part # 08600-00909. I am really confuse with the wiring , please guide me with this connection thx
Old Mar 25, 2006 | 05:18 AM
hupptoy's Avatar
I you are replacing one factory radio with another factory radio, then just unplug rear connector and antenna and plug back into the new radio.
hupptoy
Old Jan 6, 2012 | 05:54 AM
voodootoo's Avatar
Does anyone have the plugs that plug into the above referenced radio?
Im installing a factory radio back into my 90 Pick up.
Thanks,
Bret
Old Jan 6, 2012 | 08:46 AM
TheDurk's Avatar
Thanks,
Bret
Back in '99, I yanked the radio/cassette about ten minutes after I got the truck home. I installed it in one of my kid's cars that only had a radio. Toyota sells something the parts guy called a 'theft kit', for when somebody robs the stereo H/U and takes the plug and wires with it. It is the plug that goes into the radio and loose wires you can match to the truck you are putting it into. I doubt anybody besides Toyota sells this. I don't know if it is still available.
Old Jan 7, 2012 | 09:04 AM
voodootoo's Avatar
Thank you for the quick response! Ill check into it.
Safe trails,
Bret
Old Jan 7, 2012 | 04:12 PM
narfy's Avatar
scosche makes the harnesses... http://www.scosche.com/car-audio/product/683
TA02RB
anyways.. most toyota radios are electrically interchangeable from 87-08... just remember to unplug the offboard amp if the radio coming out has one... usually only found on double din units...
Old Jan 7, 2012 | 06:56 PM
kac0825's Avatar
I have the stock radio with all the plugs from my 99 4runner... It has the CD player and radio and all the plugs/amp and such.
Old Jan 8, 2012 | 08:36 AM
voodootoo's Avatar
Thank you both for the reply.
I purchased Scosche #TA02B from ebay and it does not fit. I will check out their website as you note #TA02RB. May send a photo to Scosche as well.
I really appreciate everyones help! Im restoring a 1990 Toyota 4x4 V6 with 80K original miles. (it was my dads before he passed away) CA car with no rust. Great little truck with factory AC. The only modification it has is an aftermarket stereo. I like the factory look. Bret
Old Jan 8, 2012 | 06:05 PM
TheDurk's Avatar
If you want the plugs that go into the RADIO those kits are useless. They plug into the truck harness and the wires connect to the harness that comes with an after market H/U.
Old Jan 9, 2012 | 05:19 AM
voodootoo's Avatar
The Durk - your right, I need the plugs that plug into the back of the radio. I see from your earlier post, Toyota is the only source. Ill check into it. If it is not available, I may have to go with an aftermarket stereo. Thanks.
Old Jan 9, 2012 | 07:15 AM
JBurt's Avatar
You could also look on the classifieds on here to see if someone is parting out a 3rd gen pickup, or hit up a junkyard. I doubt anyone would charge you much for that part.
Old Jan 10, 2012 | 03:02 PM
narfy's Avatar
TA02B is the adapter harness that plugs into the factory radio harness so you can splice your aftermarket harness in...
TA02RB is the replacements for the toyota harness... this works... i've tried it.. plugs right into the back of a toyota radio...
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Avenged
Jul 9, 2015 07:55 AM
skoti89
Jul 8, 2015 12:05 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
Vargntucson
Jul 4, 2015 12:15 PM
