92 4Runner suspension
Old Mar 10, 2003 | 06:52 PM
MattM1215's Avatar
I turned 16 3 months ago and got a 4Runner. It is bone stock and I am looking at getting either the downey coils and SAW t bars or a pro comp 4" suspension lift. What do you recommend? I want to fit 33" tires when im through. I dont have alot of money. Any ideas? How tough of an install is this?
Old Mar 10, 2003 | 07:29 PM
Victor's Avatar
You can fit the 33's with one of Roger's 1 inch body lifts, the Downey coils and pounding the fender seam. That would be the least expensive way to do it. If you go metric - 285/75r16 then the tire will be slightly narrower and that may help prevent rubbing but then you have to factor in the cost of those wheels.
Old Mar 10, 2003 | 08:01 PM
94 First Responder's Avatar
I would shy away from the saws unless your putting a bumber on. They kill alot of your flex (or little there of) you will be lifting up tires like crazy if your not adding front weight. Crank the stockers an inch and run some downeys in the rear and a 1in body and you will be good to go.
Old Mar 11, 2003 | 01:17 PM
MattM1215's Avatar
Downey Coils
Thanks for the help! How tough of an install is this and where should I buy the coils from? Thanks again
Matt
Old Mar 11, 2003 | 01:22 PM
doink's Avatar
you can buy the coils direct from downey i think. their link is in the vendor section of the forum. just to help you out with your decision, here is my runner with the 4inch lift and 33s. which ever way you go, you will enjoy the lifted stance of your runner.
Old Mar 11, 2003 | 01:30 PM
MattM1215's Avatar
I went to Downey.com and you have to order a $6.00 catalog. Any other online stores offer these? Are the coils hard to install?
Thanks again,
Matt
Old Mar 11, 2003 | 01:55 PM
doink's Avatar
Thanks again,
Matt
i beleive people, when ordering from downey, just call them and ask for the HD spring kit or something. hopefully someone will chime in on that note. mike at extremeoff-road.com might beable to help you out too. his name on here is XtremeOff-Road.
Old Mar 11, 2003 | 02:08 PM
Corey's Avatar
Co-Founder/Administrator
Three places to get Downeys:
1. Call the toll # on Downeys site.
Yeah, their site is lame, and it's a toll call.
2. Call up www.central4wd.com and order them.
They don't list them on their site, but that is who I got mine from.
3. Mike @ www.xtremeoff-road.com is a member here.
Make sure you get the Heavy Duty ones if you even plan on loading up the rear with gear.
For help on installing them, look in our tech section here.
There are two write-ups in there on installing the Downey coils.
Make sure you have one of these, and perhaps a friend to help you.
After you get done, sit back and smile at how good your rig looks.
Old Mar 11, 2003 | 06:23 PM
MattM1215's Avatar
Should I do the coils and the spacer pucks? Will cranking the t-bars up front make up for the 2+ inches gained in the rear?
Old Mar 11, 2003 | 06:29 PM
CTB's Avatar
CTB
I'm pretty sure that 1.5" is about all the further you want to crank your t-bars so that you can keep a decent front cv angle.
Old Mar 11, 2003 | 06:32 PM
MattM1215's Avatar
so dont use the spacer pucks?
Old Mar 11, 2003 | 06:34 PM
doink's Avatar
are you reffering to coil spacers?
Old Mar 11, 2003 | 06:35 PM
CTB's Avatar
CTB
Downey coils should get you about an 1" lift over stock height, give or take a little. Corey may have more of an exact measurement.
MattM1215's Avatar
Yes. I was trying to decide if I should use just the coils or the coils and the pucks.
Matt
Old Mar 11, 2003 | 06:39 PM
doink's Avatar
if you want to run 33s, i would say get the coils, then just get a body lift of 2 inches. i think you could do a 1inch bl , but, might have to do some fender trimming. correct me if im way of course with your plans.
Old Mar 11, 2003 | 06:46 PM
MattM1215's Avatar
Doink,
I noticed Luke had the Downey coils and the 1.5" spacers. Should I get the spacers as well. You were correct with my plans to run 33"s in the end.
Old Mar 11, 2003 | 06:51 PM
Corey's Avatar
If you are going to run 33s, you might want the spacers.
See Luke's post here, he is running 32" tires, Downey coils and spacers, and just put on a 2" body lift.
https://www.yotatech.com/forums/show...&threadid=7489
Here is an older post when he put the Downeys & coil pucks, ect on.
https://www.yotatech.com/forums/show...&threadid=3974
If you run the pucks, you should get longer shocks.
I am not up on that, so I don't know the models.
Running the above combo with a 1" body lift will let you run 33s with a little fender massaging.
Also see our forum that is called "Frequent Topics."
It is listed on the main page right below the classifieds.
There is a post in there of a truck with Roger Brown's 1" body lift kit on it and running 33s.
The problem with a 2" body lift is you will have to cut your shifter handle, lengthen your steering shaft, and other things that are outlined in Luke's post.
With a 1" body lift, you don't need to do any of that, and you can still fit 33" tires.
Cody, I am not sure how much lift I got if you factor the sag in also, but if you do, I'd say I got 4" of lift.
I was sagging a lot.
But it's probably 2" over stock not counting the sag.
Old Mar 11, 2003 | 06:54 PM
MattM1215's Avatar
Corey,
Thanks for that info. It really clears things up for me.
Matt
Old Mar 11, 2003 | 07:18 PM
CTB's Avatar
CTB
Ya, my sag wasn't horrible, but definitely noticeable. I'd say right now my rear end probably sits about an 1" or so over stock. Overall, I'm guess I probably got 3" of lift (front sagging height to current height) out of the Downey's.
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
Cdn-wilderness
Jul 10, 2015 07:43 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
Vargntucson
Jul 4, 2015 12:15 PM
