shock question
Old Mar 11, 2003 | 02:10 PM
doink's Avatar
shock question
would i have to jack up my car or do anything else along those lines to put on new shock boots? thanks:pat:
Old Mar 11, 2003 | 02:37 PM
Bumpin' Yota's Avatar
I dont honestly know. I imagine at worst you'd have to take one end of the shock off and slip the boot on. Incidently, you dont have to lift the truck and remove tires to remove shocks...
My question is in regard to sway bars....do you have to lift the truck to disconnect them?
Old Mar 11, 2003 | 05:54 PM
RTdawgs's Avatar
you have to take the shocks off to put new boots on.
you can take the sway bars off on the ground.
Old Mar 11, 2003 | 06:28 PM
doink's Avatar
i knew that much, but i was meaning, like, is it a hard process? it looks like i can just take off the top part and slide the boot on....i could do this myself right?
Old Mar 11, 2003 | 06:43 PM
keisur's Avatar
If you take the top stem bolt off you might as well undo the bottom loop too and take the whole shock out. I think that is what AllOther... was saying, that you have to take the shock completely off. Is your's a stem type on the top? Mine is and there is no way I could undo the top and slide the boot on from up there. I would have to be able to compress the shock enough to rotate it down on the lower shock mount and it won't compress that far. if you went to a bike shop you can get a pair of lizard skins for bike shocks and just wrap them around the upper part of the shock. I'm kidding.
Old Mar 11, 2003 | 07:18 PM
Dr. Zhivago's Avatar
Away
Keisur has the best avatar in the history of forever.
Dr. Z
Old Mar 11, 2003 | 07:56 PM
Adam F's Avatar
You should be able to just take off the top nut on your shock and slip the boot on and bolt it back up without taking your wheels off or anything. You might have to take the lower bolt off if you cant compress it enough to get it out. Still no biggy though.
Luvmeye22re
Aug 4, 2015 03:53 PM
makemusic116
Aug 2, 2015 05:23 PM
SMOD
Jul 27, 2015 01:45 PM
Massmayhem247
Jul 18, 2015 05:46 AM
akaphilly
Jul 9, 2015 02:34 PM
