4HI pulling to the left
Old Sep 28, 2005 | 09:18 PM
pullnshoot25's Avatar
When I put my truck into 4hi, it seems to be pulling to the left.... front alignment issue or what?
Old Sep 28, 2005 | 10:32 PM
jimbo74's Avatar
sounds liek typical binding of a 4x4 system...... especially one with an open front diff
Old Sep 28, 2005 | 10:35 PM
Adam F's Avatar
Theres nothing to bind if your going straight.
I've never driven a 4x4 that pulls to either side while going straight in 4wd.
Sounds like something is dragging, maybe in the hubs or the axles.
Old Sep 29, 2005 | 11:21 PM
well...
the pulling to the left seems to be coming from the front, not the rear... like, it feels like you are in a badly aligned FWD honda or something. besides axles, what could be dragging or causing it otherwise?
Old Sep 30, 2005 | 08:23 PM
Glenn's Avatar
Have you checked your front tire pressure lately?
Old Oct 2, 2005 | 02:10 AM
admiral's Avatar
Thats funny my 4Runner does it to the right, when going straight.
Old Oct 2, 2005 | 09:15 AM
miket223's Avatar
Check your tires. If all four tires are not properly inflated and worn evenly then 4HI will not be pleasant on the road. If you have one tire that is worn more than the others on a corner of the vehicle then it will not track straight. Same goes for uneven tire pressure. This occurs due to the different radius of the tire where it makes contact with the ground. If you think it is bad driving around in 4WD with open diffs (assuming you have open diffs), try rolling around with lockers front and rear. There is no room for tire size difference or the steering wheel will fight you to your inevitable death.
Old Oct 12, 2005 | 03:10 PM
hahah, the tire idea sounds about right.... hmmph, i had better check that out. I have open diffs, you are correct.... haha, i will do that. Thanks yota-techers!
jasonty
41
Dec 23, 2018 01:00 PM
Tykiller1994
Aug 10, 2015 07:49 PM
yourrealdad
Jul 21, 2015 11:13 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
