22re wouldn't start....then blew white smoke
Old Oct 14, 2003 | 11:14 PM
wxxyz's Avatar
Arrow 22re wouldn't start....then blew white smoke
Hey.
I have a 1990 4runner with a 22re in it. This morning, it would barely turn over, and wehn it finally turned and started, it blew a ton of white smoke out the exhaust. (the smoke smelled strangely sweet, like coolant).
Is it a blown head gasket?
Thanks
Old Oct 15, 2003 | 06:01 AM
Puddle Jumper's Avatar
Kinda sounds like it....any water showing on the dipstick?
Old Oct 15, 2003 | 06:25 AM
CTB's Avatar
CTB
White, sweet smelling smoke would indicate coolant being burned. However, I'm not sure if the only way to burn coolant is because of a blown head gasket. Someone else with a little more knowledge should chime in...
Old Oct 15, 2003 | 06:47 AM
3.4v6's Avatar
might have a crack in the head or the block letting coolant in causing the white smoke. check if there is coolant in the exhaust tip when you start the engine.
Old Oct 15, 2003 | 09:38 AM
wxxyz's Avatar
nope, no water on the dipstick.
coolant in the exhaust tip........do you mean like a liquid puddle? nothing like that, just white smoke. Although this morning, it turned over and started fine, just white smoke again.
Yesterday it seemed like it had to try and push out liquid. There mighta been coolant dripping out the exhaust then.....i didnt check
I checked the coolant level and its definitely down in the rad.....I can see the core.....but the overflow is full.....If the gasket is blown could it be over-pressurizing the coolant system causing it to blow out to the overflow tank?
thanks guys!
Old Oct 15, 2003 | 09:49 AM
Krash's Avatar
Can you rule out the timing chain? What I mean is by it eating away the cover and somehow letting coolant in somewhere.
Old Oct 15, 2003 | 11:53 AM
wxxyz's Avatar
how would i check that? I've already got the rocker cover off.....and can see the chain....but where does it rub through usually? I can't seem to see the plastic guides(or lack of) that cause that problem.
Old Oct 15, 2003 | 02:03 PM
PirateFins's Avatar
The chain rubs on the bottom right of the cover when looking down from the top of the motor. Your problem sounds exactly like the infamous timing chain rub. My truck did the same thing when my chain wore a hole in the cover. Ran fine just spit out white smoke. Try looking down the right hand side of the timming cover, you will be able to see a reverse train track looking groove.
Sorry for your luck, but if that is it, put a DOA cam in there while you got the cover off.
the1998sr5
15
Jul 14, 2020 08:35 PM
okamikai
Apr 30, 2018 10:19 PM
o2raybid
Sep 4, 2015 12:45 PM
Sandman
Jul 14, 2015 12:36 PM
raiderhawks00
Jul 8, 2015 06:23 PM
