Z's Confederate Toy's 1987 Pickup Build-Up Thread
Old Dec 13, 2010 | 07:24 AM
  #261
Z's Confederate Toy's Avatar
Originally Posted by space-junk
dont mean to poing out the obvious but WHAT THE HELL are those stains on the passenger seat?!?!
I had a cup of half n half from the gas station and spilled it all over. It was like the first day that I had the seats in the truck. I was not a happy camper, thats for sure.
Old Dec 14, 2010 | 08:47 AM
  #262
The hood latch has been broke on the truck for a while now and ya have to slam the hell out of it for the latch to work. So last night I installed some hood pins to fix my problem. They look pretty friggin good. Didnt have my camera for the install cuz my mother is in AZ with it. I will post some pics of the finished product as soon as I get my camera back.
Old Dec 14, 2010 | 09:28 AM
  #263
irab88's Avatar
aw man, you should have said something. i had the same problem. the latch wasn't broken, it had just slid down. there are two bolts that hold the latch on the frame. just loosen those, slide the latch assembly up, then re-tighten. it was a moment of triumph when i figured it out
Old Dec 14, 2010 | 01:09 PM
  #264
I should have known that it was something easy to fix. But the hood pins do look pretty bad ass now that they are there.
Passenger side:
Driver side:
Old Dec 14, 2010 | 08:37 PM
  #265
irab88's Avatar
those pins do look pretty dam good. now you just need something to lock that hood down, so nobody steals your battery or other sweet mods. i've seen it happen. maybe just a hook and cable to the cab?
Old Dec 14, 2010 | 08:40 PM
  #266
peow130's Avatar
"half and half"
yeah, thats what they call it these days.
Old Dec 14, 2010 | 08:56 PM
  #267
Im gonna run a chain from the old hood latch on the hood to somewhere prolly on the frame with a pad lock.
Originally Posted by peow130
"half and half"
LMAO. I figured someone would go there
Old Dec 14, 2010 | 09:22 PM
  #268
taggart_lumpy's Avatar
mmmm old school vw gli recaros
by far some of my favorite seats of all time
i have a set in my storage ive been waiting to use
Old Dec 15, 2010 | 08:01 AM
  #269
They are awesome. Very comfortable seats. Definitly couldnt skimp on comfort any longer.
Old Dec 15, 2010 | 08:07 AM
  #270
87hillbillyoter's Avatar
hood pins look good man
Old Dec 15, 2010 | 08:20 AM
  #271
irab88's Avatar
Im gonna run a chain from the old hood latch on the hood to somewhere prolly on the frame with a pad lock...
or you could still fix the latch and keep the pins. that way you wouldn't need another key on your key ring
edit: also, any pics of your interior? i'm interested in how you mounted your cb radio
Old Dec 15, 2010 | 08:31 AM
  #272
Thanks
Thats a good idea. I will post some up here in a minute if i can find them.
Old Dec 15, 2010 | 08:53 AM
  #273
I cut a hole in the stereo mount thingy where the cubby used to be.
Then I slid the CB into the hole I cut.
Then I used this fuse block for the power. I ran the wires through an existing hole in the firewall
Old Dec 15, 2010 | 09:18 AM
  #274
irab88's Avatar
cool, thanks
Old Dec 15, 2010 | 10:25 AM
  #275
No problem
Old Dec 15, 2010 | 10:40 AM
  #276
so what are you doin next?
Old Dec 15, 2010 | 11:01 AM
  #277
Up next is the motor. Ive found a used one for 700 at one of the local yards. Hes put a new timing set, new bearings and says its got 150 compression. I will prolly pull the old one today and pick up the used one tomorrow.
While Ive got it in the shop, I will be replacing the rear wheel cylinders, cranking up the torsion bars, puttin some Early Bronco leafs in the rear and a U bolt flip.
Just did a compression test on my existing engine.
1st cyl: 100 psi
2nd cyl: 90psi
3rd cyl: 50 psi
4th cyl: Didnt even bother
Old Dec 15, 2010 | 07:23 PM
  #278
twistedyota's Avatar
700? thts a lot
Old Dec 15, 2010 | 07:27 PM
  #279
Swimmerboy2112's Avatar
What you found is why im afraid to compression check my engine...
Old Dec 15, 2010 | 07:51 PM
  #280
space-junk's Avatar
700 is a lot for a used motor... i bought a used 3rz for 200 and i had people tellin me that i was crazy...
