yotarob2005's 1986 4Runner Build-Up Thread
Old Mar 11, 2010 | 01:13 PM
  #41
yotarob2005's Avatar
I agree & would recomend Ted to anyone in the future.
Old Mar 12, 2010 | 08:51 AM
  #42
UPS just dropped off my head gasket set from ENGNBLDR. I am very pleased, this set includes a lot of gaskets that I didn't expect it too. I also got new head bolts. Unfortunatlly, I don't think I am going to have much free time this weekend to work on putting the motor back together.
Old Mar 13, 2010 | 07:43 AM
  #43
After a bunch of searching, I have decided to pack my oil pump with Sta-lube marine wheel bearing grease to "prime" it.
I bought some VHT header paint to dress up my exhaust manifold, it says it is flame proof & good up to 2000 deg. Trying to track down a decent source for some 10mm x 1.25 lock nuts to replace the rusty one on my exhaust manifold with out getting rapped at the dealership. Anyone have any ideas? I tried Mc master Karr, but all they have in nylon inserted which would not hold up to the heat, none of my local stores have any.
Old Mar 16, 2010 | 04:53 AM
  #44
It has been a few days since I really got anything done, I did manage to get the engine compartment cleaned over the weekend.
Last night I set out to lap the valves. It was somethnig new for me, but once I got going it went very well. I did all of the intake valves first, the sealing surfaces looked to be in pretty good shape and I spent maybe 10 minutes per valve polishing them with the fine grit compound. Then the exhaust valves where a whole nother story! The sealing surfaces where COVERED in carbon build-up. I only got 2 of the exhaust valves done because I had to work them for well over an hour each, but they still came out great, just took a bunch of time to restore the finish on them. I did not take any pics because I left my camera at work but I will get some tonight when I finish the last 2 valves. I feel good about what I am doing here, pretty damn sure that I was loosing some compression around the exhaust valves. Also replaces the valve seals as I went.
Old Mar 16, 2010 | 04:58 AM
  #45
92 TOY's Avatar
sounds like you and me are at about the same point here.
glad to hear, doing the valves not such a big deal....give me a clue or a linky as to how to do that...i haven't really searched that one yet.
supposed to be around 60 today so i think i will get some stuff done.
Old Mar 16, 2010 | 05:35 AM
  #46
Here is the first link that I found for the clover compound I am using.
http://www.amazon.com/Greased-Silico.../dp/B002P51XVS
I have 100 grit for a course & 320 for fine, or finish. It is basicly grease with silicon carbide grit mixed in & the idea is to release the valve spring & put the grease between the valve & valve seat & re-install the valve with out the spring. The suction cup tool (pictured below) goes on the face of the valve and gives you a handle to turn the valve while holding light pressure against the valve seat. Doing this will make the 2 sealing surfaces mate.
From what I was told about it, you should turn it both directions, back & forth, at a pretty slow rate. It is not a good idea to grab the valve stem in a drill or other rotory device to turn it, belive me I was tempted too. The tool worked great on the intake valves but I had a hard time getting it to stick on the exhaust vlaves. The end with the big cup was just a little too big & the small end was a little too small.
92 TOY, I highly recomend that you take the time to do this IF you do not plan on taking your head in for a valve job. Lapping the valves is what is known as a poor mans valve job & it isn't hard or expensive to do. I originally wasn't going to bother with it, but a good freind convinced me to go ahead & do it since I was going to have to pull the valve springs out to change the valve seals anyway. Boy am I glad I did because my exhaust valves where in pretty bad shape. Like I said, I will get you some pictures up late tonight or tommorow morning.
Old Mar 16, 2010 | 05:53 AM
  #47
92 TOY's Avatar
thanks...
yeah LUMPY posted a pic of the tool a while back (somewhere on my thread) and also a video link of a guy doing it. I know you have to compress the spring (right?) and i was just curious how to do that....is there a tool for that? or is it just a matter of getting a good suction on the valve.
i was just doing some putzy work on mine. will post up on my thread as soon as the pics load.
Old Mar 16, 2010 | 06:05 AM
  #48
Yes there are several types of tools to compress the spring, I will take a picture of the one I am using. I was able to borrow it from a freind which saved me some money. I'm pretty sure you can rent them from the auto parts store.
Old Mar 17, 2010 | 04:32 AM
  #49
I got a pretty late start last night but did finish lapping the valves. I realy,really tried to get some before & after pics of the valves but I could not get a picture close enough to show the detail without ending up blury. I guess you guys are going to have to take my word for it that all of the valves look great & I am 100% confident that I did some good getting them to seal. I hope to get an earlier start today after work, maybe with one more day of prepping/ cleaning & 1 more trip to the auto part store for odds & ends, I will have this thing all ready to be put back together.......I hope.
Old Mar 17, 2010 | 05:00 AM
  #50
92 TOY's Avatar
sounds good
Old Mar 17, 2010 | 05:32 AM
  #51
If anyone want to throw an old tired dog a bone, I am searching for torque specs. I do have a Chilton manual but it seems to be pretty worthless for torque specs. Does anyone have a link to the FSM or a nice chart would be great.
Old Mar 17, 2010 | 05:49 AM
  #52
92 TOY's Avatar
Hey....my problem exactly last night. (see my thread, FLYINGBRASS pulled my butt away from the fire on that).
What specs are you looking for? I'd be happy to post up what I already know.
Old Mar 17, 2010 | 06:11 AM
  #53
thanks buddy, for now I need the oil pan bolts, timing cover, water & oil pumps.
Old Mar 17, 2010 | 06:16 AM
  #54
92 TOY's Avatar
oil pan are 9 ft/lbs
timing cover says 8mm bolts (apparently NOT head size but actual thread size) are 9 ft/lb and 10mm bolts are 29 ft / lbs
as far as the pumps go, I cannot find that info....
Old Mar 17, 2010 | 06:18 AM
  #55
Thanks again. I will keep searching for the spec on the pumps & let you know if I find it.
Old Mar 17, 2010 | 06:22 AM
  #56
92 TOY's Avatar
I get TED from ENGNBLDR will know.
the thing is, in the FSM in the back, it has a way to read the bolts to determine specs....this shape bolt with this size thread width with this many markings equals this many ft/lbs.
Old Mar 17, 2010 | 06:24 AM
  #57
Lumpy's Avatar
I had a Haynes Manual and I believe it had all the specs.
Old Mar 17, 2010 | 06:29 AM
  #58
92 TOY's Avatar
I'm gonna disagree......although not quite sure.....but, of course, now I will look....but the manuals all are mostly worthless to me.....hell all of them together couldn't get my oil pan off the right way until I came up with a new way........GO ME!!!!!!
Old Mar 17, 2010 | 06:31 AM
  #59
Water pump torque specs:
6mm bolts w/ 10 mm head are torqued to 13 ftlb's
Long 8mm bolt w/ 12 mm head is torqued to 14 ftlb's
my source.
http://wiki.answers.com/Q/What_the_t...ter_pump_bolts
Old Mar 17, 2010 | 06:32 AM
  #60
I will look & see when I make my next run to Napa if they have a Haynes & if the spec are there, thanks for the tip!
