vang_22re's 3rd gen pickup build thread
Old May 12, 2012 | 07:24 AM
  #141
vang_22re's Avatar
I picked up a set of DNJ RINGS. got it from a shop my dad order all his parts for years when he was still doing mechanic work. They are chrome rings. I think its a reboxed NRP rings. Same packaging just different cover. I'll take a dive and make them seat
Old May 12, 2012 | 09:48 AM
  #142
ChefYota4x4's Avatar
WWWWWWWWWWWWWWWWOOOOOOOOOOOOOOOOOOOOOOTTTTTTTTTTTT TT! HEHEHE. Can't wait for that Video!
Old May 14, 2012 | 05:10 PM
  #143
vang_22re's Avatar
Alrighty. I was putting the crank in and just bearly started to tighten it and the crank dont want to turn!!!!! ahhhhh mayb the bearing got mixed up? Who know. Haha so yea ordered a set of crank and rod bearing so everytging is on hold again for a couple of day. This rebuild is not going smooth at all!! Hahaha and its hot here too. No ac in the garage!! But there is a swamp cooler out back that i should bring in. Sounds like a plan hehehe
Old May 14, 2012 | 08:26 PM
  #144
Sure you didn't just mix the caps up? You labeled them? Torqued the first of the 5 down and checked for ease of turning/then so forth?
Old May 14, 2012 | 09:55 PM
  #145
vang_22re's Avatar
Caps were right 1-5. I put the old crank into the new block. Souldnt make a difference? Don't see why not. Hahaha the old crank was nice and quiet and have no clue what the donor crank's condition is.
Old May 14, 2012 | 10:05 PM
  #146
ToyoTech559's Avatar
if your using the old crank in the new block. you need to use the correct bearings. if you dont know the right ones than you need to plastigage to figure out what size bearings to use
Old May 14, 2012 | 10:17 PM
  #147
vang_22re's Avatar
Yea. The old crank is .25mm (.010") so I'm guessing is the old bearings are probably use to or seated to the crank's surface. Mixing then up might have affect the micro groves? Haha. Just a thought. That causes the crank to not turn freely. Of what do you guys think? Should the crank turn even with all bearing being mixed?
Old May 15, 2012 | 10:09 AM
  #148
You just HAVE to order bearings to the grind... 10/10, 20/30, WHATEVER, lol. Mixing up the 'CAPS' is where I had trouble... Found the right order by pictures again and voila! Shouldn't matter that much, since I had them bore/honed micrometers to rounded again.. But it did, especially on the main caps. My crank was a 10/10 grind.... so ordered Sankei OEM Old/New stock off ebay... Got the caps right and it was like warm butter and a knife from there on out. Make sure you lube em up really well. Did the shop label the caps as they took them out? Because, it wouldn't matter, but like mine, I had a new block AND crank from same block.... So with minimal rounding of them on the machine(the rod caps and rod journals) it didn't change enough to be a problem.... but with the main caps, they were a lot harder to bore/hone without removing more and then needing even another step up in bearing size(grinding off the crank surface AND opening up the cap/journal surface changes things, doubly, make sense?)
Sorry, I'm rambling, ... explain EXACTLY what they did to the block, journals, crank, k? (A new block was used with your existing crank, right?)
Old May 19, 2012 | 07:13 AM
  #149
vang_22re's Avatar
Yea new block with old crank. I just went ahead and order a set of bearings. Havent even had time to put them on yet with graduration season happening. But hopefully sunday tomorrow
Well anyways i was looking into winches the pass couple of weeks. Dont ask why haha just popped in my head haha. So i was looking into buying a smittybilt xrc8, fair price for an 8k winch. Actually pretty cheap other than the habor hieght products. Ill let you guys know how everything goes
Old May 19, 2012 | 10:56 AM
  #150
4wheel parts has a special on winches right now i think
Old May 19, 2012 | 06:09 PM
  #151
vang_22re's Avatar
Alright cool ima check them out. Ima tell them the guy that bought the ARB and warn winch told me maybe they'll give me extra discount haha jk
Old May 19, 2012 | 06:26 PM
  #152
i got an xrc8 winch
Old May 19, 2012 | 08:42 PM
  #153
vang_22re's Avatar
I sorry haha I really just thought u had a warn. Must had mixed it up with someone else's setup or just maybe being stupid haha
Old May 20, 2012 | 07:38 PM
  #154
vang_22re's Avatar
Alright guys and girls!!! Remember when i had that crank problem couple of messages ago hahaha i found the problem. I have two blocks, using the old crank in new block, used current main brarings, crank did not want to turn! So i bought a set of new bearing. Main, rod and trust. I slapped on the new main and what do you know, same problem!!!!! My head was exploding at that moment.
So i thought about it. Maybe im using the wrong main cap from the old block. Put the other set of main cap on and what do you know!?!?!? It works. Turns as smooth as butter haha
Just thought i should share the story. O yea gonna go and check out the smitty xrc8 tomorrow. So excised!!!!
Hey toyo, did they have to order your winch or did they have it in stock?
Old May 20, 2012 | 08:55 PM
  #155
good to hear the motor is coming along
they usually carries xrc8 because they sell a ton of them.
Old May 20, 2012 | 09:37 PM
  #156
Hey, .... Roger, ..... I'M EXCITED FOR YA! lol.
Hmmm, 'switch the caps', ...get outta heeeeeeeeere!! hahaha. No, but you definitely wanna keep the same caps and crank together.... GREAT news! OH< btw, .... when you said, "MY head was exploding!".... HOLY CRAPOLI, that freaked me out for a second, man! lol. Not that I'd rather your ACTUAL head explode... but yeah, glad to hear the Toy Head is good to go! lol.
Old May 20, 2012 | 09:47 PM
  #157
vang_22re's Avatar
Thanks Toyo. Thats good to hear about the winch we will be wheeling soon 4:56 is in the runner. That's if the truck isn't ready yet
Mark, my actual head was gonna explode with veins pumping and everything haha but hopefully this job gets done soon so I can start another one haha
Old May 20, 2012 | 10:45 PM
  #158
Another project, Roger?
Old May 21, 2012 | 06:38 AM
  #159
vang_22re's Avatar
I was talking about the winch project haha
Old May 21, 2012 | 09:31 AM
  #160
Outsane's Avatar
nice find... glad it didn't come down to a any grinding
