vang_22re's 3rd gen pickup build thread
Old May 21, 2012 | 12:21 PM
  #161
vang_22re's Avatar
Thanks outsane I'm glad also
Old May 24, 2012 | 07:36 PM
  #162
vang_22re's Avatar
Alright I stopped by my parents house to see how the truck is turning out. O yea I forgot to say since I don't have that much time I let my dad put the engine back in. So I went over and it looked pretty good. Stayed there for a while and head back I went back after work and helped him finish it off turns out he popped his heater hose so he used mined haha replaced that and he also took my battery cause his die. But we jumped it really quick and got it running. "the sweet sound of the engine" click click click.. Hahaha I looked over and smoke was coming out crazy out back! NO!!! Turned off the engine and adjusted the timing, it was too retard. Fired it up again and wonderful! Nomore smoke click is gone hehe sounds better than the first time. Didn't test drive it yet don't have a clamp for the heater hose yet let's see how these DNJ (NRP) rings holds up
Almost there
My dad under the truck working his magic
Old May 24, 2012 | 07:38 PM
  #163
ToyoTech559's Avatar
sweet. finally got it done.
Old May 24, 2012 | 07:41 PM
  #164
vang_22re's Avatar
I know right. Finally. Now time to reinforce my bumper brackets and throw on the winch
Old May 24, 2012 | 07:49 PM
  #165
reinforce? isnt that bumper made for a winch? i didnt have to do anything to my arb bumper to use a winch
Old May 24, 2012 | 07:59 PM
  #166
vang_22re's Avatar
O no. The bumper came off of a fj80 and it was too long so we cut and weld it to size and made cheep brackets to hold it up. But now I have to make better brackets.
Old May 24, 2012 | 08:27 PM
  #167
ooo haha that makes sense now. should be hard if you can make a FJ80 bumper to fit your truck
Old May 24, 2012 | 09:11 PM
  #168
ChefYota4x4's Avatar
Wow, GREAT NEWS! woot, ... and 'CHEEEEEEEEERS FOR POPS!' What a cool dude!
Old May 24, 2012 | 09:52 PM
  #169
vang_22re's Avatar
Haha thanks mark, pops is a good guy. He thought me everything I know about working on cars.
Toyo, cutting the bumper wasn't that bad just about two inches on each side
Old May 26, 2012 | 07:27 PM
  #170
vang_22re's Avatar
I drove the truck home today and notice a slip on the clutch! Gosh! But it was driving good other than that. Drive it about 15 miles back home. It felt good. Got home parked it and saw a leak on the gear box hopefully just a loose clamp didn't really look at it, I was too tired. I'll check it out tomorrow
Old May 26, 2012 | 11:49 PM
  #171
Sorry man! Well, now, .... gear box? Steering gear box? I know you said "clutch slipping"... but curious if you transitioned there into something else you noticed? Could the motor, when dropped in, have nicked or banged up one of the lines?(unless you're talking about the t-case or trans? lol.) When my input shaft seal on the trans was leaking, I had no slipping, but wanted to get to it asap..... SO I TORE THE MOTOR OUT! hahaha. JK, I was doing that anyhow, and wow, was that seal leaking gear oil BAD! It would have eventually destroyed my new clutch kit and was making a mess with that STANK gear oil! lol. Swapping in gear boxes was lots of fun, too lol. (if it is the steering, grab a 2WD box... it's the SAME BOX and will have done about 1/2 the work, at most! I did, happy I did so... steering is like a hot knife through warm butter now!)
Old May 27, 2012 | 11:03 AM
  #172
vang_22re's Avatar
Ooooop haha sorry steering I meant haha. I think the line is too worn out. The power steering pump was never remove outside the truck just pushed aside. Maybe just sitting there for too long cause some breakage on the line but who knows. Still haven't checked it out yet. Haha. But I should Ge to it
Old May 27, 2012 | 11:28 AM
  #173
vang_22re's Avatar
Just walked outside and looked at the leak. It doesnt look like it but its coming straight down the steer box. Aw man the apartment manager is going to enjoy my company hahaha
Old May 27, 2012 | 11:44 AM
  #174
apartment? OH BOY, yeah, been there, ....that can ruin a tenant/manager relationship for sure! "Get some clumping litter and Simple Green and CLEAN THAT UP, SON!" hahaha.
Anyway, sorry bout the leak. I've dealt with this, maybe in a different 'cause', but nonetheless, steering can be a bear and a messy one. BTW, IF that hose decides to BUST.... you're talking about 1200# of pressure at times.... NOW you'd be talking 'MESS' in the 'catastrophic' realm, if it completely gave up.
1. Look on the back of the pump near the idle up vacuum port(if you have one on your year)... Mine began to leak after swapping it in and out 3 times for engine swaps.... THEN, when I replaced the starter, I HAD TO use teflon high temp/pressure thread sealant on that. I also used it on the tapered flange nut that goes in the side. When moving that out of the way, the pump, that line can turn and break loose that flange nut.... CHECK IT! HOPE it's not the box.... that SUCKS! But, even that is a one day doable job. The bleeding and flushing takes most of the time... Just hated the steering wheel alignment and all that.
ALSO, IF YOU GET A GEAR BOX..... GET ONE WITH THE PITMAN ATTACHED AND DO NOT REMOVE IT! Leave it where it's 'PRE-MARKED' already.
Let us know if you find the leak, ok? Rooting for ya, NOW KILL IT! (NOOOOOOO, not your Manager, Vang!) hehehe.
Old May 28, 2012 | 07:33 PM
  #175
vang_22re's Avatar
Found the leak. It was just a hole on the hose. Replaced it and spray a whole bunch of carb choke on it. Nomore leak haha hopefully it stays that way
Old May 28, 2012 | 08:45 PM
  #176
Fhewwwwwwwww hahahaha. NICE!
Old Jun 1, 2012 | 08:56 AM
  #177
vang_22re's Avatar
An update.....
Truck runs good (check)
Oil burnage (oil level haven't drop yet with 160 miles)
Clutch slips - I notice that it slips more when it a cold start. And doesnt slip as much when it warm. Doesn't seem to slip as much as before but maybe I just got use to it haha and only slip when I give it a good amount of throttle on low rpm. I took the on ramp going uphill on the highway and no slip neither...huh...
But other than that it runs nice jut a little stiff cause of the t-bar crank (I can use those BJ spacer Toyo) haha jk
Here's a quick pic I snap hehe
Old Jun 1, 2012 | 11:56 AM
  #178
Looking good, man! Interesting on the clutch... You'll figure it out and handle it soon enough
Old Jun 1, 2012 | 12:51 PM
  #179
vang_22re's Avatar
Yea Ima drive it till it blows up. Haha naa jk but camping season is coming so I gotta make decisions quick
Old Jun 1, 2012 | 01:03 PM
  #180
Roger, ... honestly? I KNOW you don't wanna hear this but, ..... did you have the Flywheel done? If so, great... If not, I would have. Also, if the clutch is in question/or the parts therein..... I would just get it over with and make it the LAST MECHANICAL THING THIS THING NEEDS FOR A LONG TIME! Ya know? One weekend is all you need to drop and replace clutch and re-button up.... IF you need it, of course. No pics of the disc or pressure plate while it was out?
