vang_22re's 3rd gen pickup build thread
Old Feb 2, 2012 | 09:56 PM
  #61
vang_22re's Avatar
Yea I hope so too haha also have to take the time to break it in too. Still wondering which method I'm going to use to break in this motor
Old Feb 2, 2012 | 10:50 PM
  #62
yotaman85's Avatar
sometimes you have to file the rings to get them to fit..
Old Feb 3, 2012 | 07:03 AM
  #63
vang_22re's Avatar
What! Are you sure you got the right ring size haha I just return it while there still under warranty haha
Old Feb 3, 2012 | 07:01 PM
  #64
ToyoTech559's Avatar
take it easy the 1st 500 miles. than change oil. drive a little harder and from there you should be good. kinda like a new car break in.
i person prefer to drive it like i normal do but thats with a new car. dont believe in new car break in process anyways.
Old Feb 4, 2012 | 07:34 AM
  #65
vang_22re's Avatar
Yea im probably just going to drive it normally and do thelow mile oil changes along the way haha
Old Feb 4, 2012 | 09:04 AM
  #66
ChefYota4x4's Avatar
Unless it's a new CAM, it's just about the oil/metals therein. Personally, I would run it for around 30 minutes on cheapest oil you can find on sale, change the oil, then 1000 miles, change the oil, then back to normal. You know, 'NOW DRIVE IT LIKE YOU OWN IT'! The 30 minute thing is just to get any of the debris/metals falling off the fresh rings, etc., and engine assembly lube outta there, right quick, and then just drive it till 1000 to get the rings to fully seat(they should have by then, AT THE LATEST).
Have fun, man.... waiting for drive by videos......they're coming, right? hahaha.
Seriously....
Old Feb 4, 2012 | 06:44 PM
  #67
vang_22re's Avatar
I'll think about drive bys haha but should be close to done soon. And new rings fits perfectly
Old Feb 4, 2012 | 07:45 PM
  #68
Great news, man! I new it was just some fluke! Can't wait for that first start up video..... Wishing you the best!
Old Feb 4, 2012 | 07:59 PM
  #69
vang_22re's Avatar
Thanks chef.
Will give updates
Old Feb 6, 2012 | 09:18 PM
  #70
truckman1966's Avatar
I have always had great success with;
start with 30W Non-Detergent
Break new cam in for 20 min at 2500 RPM, shut off, and
change the oil (30W ND)
start and run just like you used to drive it, just try to not maintain a speed, vary it a little bit. up and down 5 mph consistently. do this for 100 miles.
drive it completely normal for another 500 miles,
change the oil (5W-30)
and then get onto your normal 3K mile oil change intervals for 15K.
don't bother with synthetic. waste of money if you buy a true synthetic. anything affordable that claims to be a synthetic is not a true syn. only a blend. so stick with castrol or quaker state. and for the love of god no fram filters. so much hate for fram. the construction is garbage. keep on top of your oil changes and use quality filters regularly and you wont have a problem. (I've built quite a few 20R/22RE's, all using this method)
Old Feb 7, 2012 | 11:09 AM
  #71
vang_22re's Avatar
Ok everything was going good until about 5 min of engine start up. There seems to be a ginormous leaf I'm guess from the piston rings again!!! Ther was more smoke from before and my only hope now is to take it out again and take it in for some machining.
Old Feb 7, 2012 | 12:46 PM
  #72
Leaf? Anywhooo, I'm assuming you mean PLUMES of smoke....... Dangit!
Yeah, that's why I was hoping you'd have the block dial indicator tested and make certain the holes aren't Eggs. (I think you did, no?)
So, it's continuing to smoke, eh? It's not engine lube, etc., at the point you're at, right?
Can you do an in depth rehash of everything done to/invested in this motor? I'm curious if you've done the guides and such, just can't remember, sorry. Maybe a;
1. Head is fully rebuilt using >>>>>>>
2. Timing kit new
3. New rings on PO's pistons/PO's Block
4. Etc., ???
5. Had the pistons thoroughly tested for damage, etc.(??)
Old Feb 7, 2012 | 03:01 PM
  #73
vang_22re's Avatar
Everything was working good before just a lot of oil consumption then the head gasket blow. That was when I decided to rebuild the engine. There was no blue smoke before the rebuild so I assuming the cylinders are not egged out
Cylinder head only have the valve stem seals changed...didn't do the guides. O yeah also had it checked and deck and was in good shape
Timing chain was reused cause I'm cheap and put in new chain guides and that was it
Rings are .20 (.50mm) over size on PO's piston. I measures the piston but didn't record it so I forgot what it was hehe
Old Feb 11, 2012 | 09:54 PM
  #74
vang_22re's Avatar
Took the boys and girlfriend to see some snow today. Didn't go really far at all until I started to lose traction due to "almost" bald tires Doug (small one) looks weird cause he's wearing a jacket and Socrates, like he's always doing, enjoying the snow
And only spot we can park so we won't get stuck cause the 4:56 is not yet in the front haha
And one with Socrates popping his head out
Old Feb 12, 2012 | 07:23 AM
  #75
nice pictures. still lot of snow or its melting lol
Old Feb 12, 2012 | 08:11 AM
  #76
vang_22re's Avatar
It's getting there more on the melting side but there was a light snow fall rite before we got there. Fresh snow on the road mixed with the wet water caused us to lost traction haha
Old Feb 23, 2012 | 08:13 PM
  #77
vang_22re's Avatar
Alright guys motor is once again out of the truck and I promise myself this well me the last time it came out for a long time! Haha let's hope for the best
Old Feb 23, 2012 | 10:34 PM
  #78
RMP8080's Avatar
Good luck with the re-build, yea I said the same, put out a working 22R to put in a 4.3 V6 go figure
Old Feb 24, 2012 | 06:55 AM
  #79
vang_22re's Avatar
Gas prices are too high for 4.3 right now haha
Old Feb 24, 2012 | 08:22 AM
  #80
RMP8080's Avatar
True, but maybe when I finish it may get better, not
