rustED's 86' V8-Runner Build-up Thread
Old Sep 7, 2012 | 10:48 AM
  #541
racerflea's Avatar
Or some creative linkage set up lol
Old Sep 9, 2012 | 07:31 AM
  #542
rustED's Avatar
Well, I'm.going to take the day off from packing, hopefully I can get the tranny and t-case swapped out today. The only problem I foresee is that I want to replace my new NWOR throwout bearing with an OEM Ford throwout bearing. Hopefully one of the parts store has one in stock. I had nothing but problems with the NWOR TOB trying to fine tune it to where it wouldn't make a squeeling sound. I made the slave cylinder plunger pushrod adjustable, and never could find the sweet spot. The PO was running an OEM TOB, and when I removed it it was worn out, but you wouldn't have known by driving it, never made any noise.
Old Sep 9, 2012 | 08:54 AM
  #543
racerflea's Avatar
Unfortunately NWOR seem to have a bad rep for part quality LOL
Old Sep 9, 2012 | 10:08 AM
  #544
ChefYota4x4's Avatar
Good call.....
Hey, ...... I'm excited for the update... Does that mean I'm now going to not only have Toyotaticulitus.... but now Fordyotaticulitus??????? .... this never ends lol.
Old Sep 9, 2012 | 10:14 AM
  #545
racerflea's Avatar
I think all is well as long as ur not suffering from irritable NWOR syndrome lol... sorry ED its just ur not the first person who has had bad stuff to say bout them
Old Sep 9, 2012 | 11:21 AM
  #546
rustED's Avatar
Good call.....
Hi Mark,...sorry about the Fordyotaticulitus! Hopefully it doesn't burn when you pee!
hey racer, well, I'm not necessarily saying that the problem was from the NWOR TOB, I think the problem lies in not knowing what the PO has done, and what parts he used previously. I reused the clutch that was in there because it wasn't slipping, it looked like in was in good shape, and I didn't have the money to replace it at the time. I'm starting to think that the PO put an OEM clutch kit in it (instead of the NWOR clutch, therefore maybe the NWOR TOB I used didn't work well with the OEM clutch? Anyway like you, I've also heard people say negative things about their quality, but looking at there bellhousing casting, its beefy! I'm also running their motor mounts and am happy with the design and quality of those. I've talked to them several times over the phone and they've always been helpful. Anyway, just wanted to clarify that, lol, Its probably my own fault for being cheap and not just buying a complete clutch kit, lol.
I'm starting to doubt that I'm going to get this done today. I keep getting interrupted, my wife had to go get more boxes for packing, so I'm watching the kids right now, lol. I drained the gear oil out of the tranny and t-case from the G52 that's currently in the runner and found this stuck to the drain plug of the tranny
I'm sure there's more where that came from, it sounds horrible, lol.
Old Sep 9, 2012 | 11:43 AM
  #547
racerflea's Avatar
Yikes!!!!!
Old Sep 9, 2012 | 09:34 PM
  #548
rustED's Avatar
Well as I feared, I didn't get much accomplished today. I was hoping to have the tranny swapped and be done, but it didn't work out that way. I got the new to me tranny and tcase cleaned up, and got the radiator, starter, clutch slave cylinder,and electric fans removed. I had to order a throwout bearing, should be here Tuesday. I have a couple appointments tomorrow, so Ill probably just spend the rest of tomorrow afternoon packing up the moving truck ( my uncle loaned us a big enclosed truck, looks like a uhaul, saved us some $$$). Probably get back to work on the runner Tuesday. Man I'm cutting it close!!!
Old Sep 11, 2012 | 12:07 AM
  #549
Terrys87's Avatar
Hope it goes well for you. I agree with liveofforads get it running on a budget comment. Atleast you can still enjoy it instead of being a yard ornament. Between the move and repairs, you have your work cut out for you. Hang in there. Things will eventually settle down.
Old Sep 11, 2012 | 06:50 AM
  #550
rustED's Avatar
Thanks Terry. I'm hopeful that this tranny will last me awhile, it sounds really smooth when you spin the input shaft and run it through the gears in 2 hi, 4 hi and 4 low, plus when I drained the gear oil out of this one it looked like honey, and I didn't see any metal particals, so I'm I'm really hopeful!!! I'm going to try to get her finished up today, since we are moving Thursday!!!
Old Sep 11, 2012 | 07:02 AM
  #551
racerflea's Avatar
Good luck!!!!
Old Sep 11, 2012 | 07:43 PM
  #552
rustED's Avatar
Thanks racer. I got the new tranny and tcase in today, Ill finish it up early tomorrow morning, all i have left is to reinstall the radiator and electric fans, and fix my hacked up exhaust. Last time I did the exhausted I sleaved the pipe on one end and used muffler clamps. The other end was welded, anyway the clamps were sinched down so tight that I couldn't pull it apart, ended up cutting both sides, so now Ill have to welded it back together, lol.
Old Sep 11, 2012 | 07:46 PM
  #553
ROCKGUY76's Avatar
Good to hear your making progress. Looking forward to hearing it's back on the road!!!
Old Sep 11, 2012 | 08:52 PM
  #554
rustED's Avatar
Thanks Travis. Tomorrow and the rest of the weeks going to be really busy for me, so I hope to finish up the runner tomorrow morning, and test it out on the way to my wife's uncles house where its going to stay for a couple days. Then were moving up to the new house Thursday (about 5 hrs away), and unpacking, I have a job interview Friday, my wife and I are coming back Saturday to pick up my two kids and the 4runner, then headed back up to the new place, lol, so I hope the 4runner makes it this time!!!
Old Sep 11, 2012 | 11:42 PM
  #555
Wow, how flipping exciting, man!!!!!!! I'm so stoked for ya, Ed!
Biting nails in anticipation of the Maiden Voyage to "Big Red's" new home! lol. Best to you and your family, ED
Old Sep 12, 2012 | 12:34 AM
  #556
PS> Posted this on my build... BUT, since I'm sure you're VERY busy and might not be able to keep up with the subs for a while... Thought i'd share here....
Pulled up to a Light on PCH and Crenshaw, in Torrance, CA... when I hear this rolling of a 302, BEEFED, ..... CAM and all... It was also turning left... and I thought, "WOW, my Yotatech-Brotha rustED would LOVE this, seeing as he's a Fordticulitus Survivor and all!", hahaha.... THING SOUNDED SICK, ED>>>
Old Sep 12, 2012 | 04:25 AM
  #557
Redeth005's Avatar
Don't forget to post up some pix when you're done with the installation. I wanna see how it comes out
Old Sep 12, 2012 | 09:58 PM
  #558
rustED's Avatar
Thanks Mark, I got the runner done today and tested it out about 10 miles over to my wife's uncles house. It drove and shifted flawlessly, also I replaced the throw out bearing with an OEM one, and it works a lot better, with NO squeeling issues, so I'm happy about that!!! We're heading out for the new house tomorrow, and will come back for my kids and the runner Saturday, so hopefully all goes well for the next few days!
By the way Mark, that car is sweet! My mom used to have an old Maverick, always thought they'd look good fixed up.
Hi Richard, I didn't have time to take any pics, but I'll do more of an update once I get settled in.
Old Sep 12, 2012 | 11:06 PM
  #559
WOO HOOO! OH, btw.... did you leave the kids enough Goldfish Crackers and Water when you tied em to the freeway underpass re-bar that's exposed under the overpass? Just checkin! hahaha....
JK, OBVIOUSLY... and wow, they excited or ticked? lol.
Old Sep 17, 2012 | 12:48 PM
  #560
rustED's Avatar
Ha, ha. The kids are excited. We're enrolling my daughter in the second grade today. My son doesn't start school till next year.
Well the 4 runner made the trip!!! The tranny held up good. Did about 70mph most of the way. My speedo is about 5 MPH off, so when I'm doing 65, its really 70. Also my gas gauge is a little off. We left Yakima, drove 200 miles to Spokane and my gauge was reading empty, I was thinking I'm in trouble if I can only go 200 miles on tank of gas! But when I topped it off it only took 14.5 gals, so I must have had about 3.5 gals left in the tank. I had my wife use her trip odometer to track my gas mileage since she was following me in her Durango, and I knew mine wouldn't be accurate with the bigger tires. We traveled 199.3 miles, it took 14.5 gallons to fill it, so that comes out to 13.69 miles to the gallon, not to bad considering I was driving with the windows down, and it seemed like there was a strong cross wind for the entire trip, lol. I'm thinking with a little tuning (carb is running rich, acts flooded when I try to restart the engine after its warm) I think I could get it close to 15mpg... not the best, but a give up some mpg's for the extra HP!!!
So it might be a week or so before I'm back on the forum, my cellphone doesn't get reception at our new house, and we aren't getting internet (Hugh's net) until Thursday, so Ill have to catch up on everyone's threads then, lol!
