RMP8080 1987 Pickup Build-Up Thread
Old Feb 21, 2012 | 09:32 AM
  #81
liveoffroad's Avatar
nice clean build! subscribed. can't wait to see that chevy purring under there
Old Feb 21, 2012 | 02:10 PM
  #82
RMP8080's Avatar
thanks, hope to get the V6 to the shop the end of the week.
I'm in training all next week and may not get things done
Old Feb 22, 2012 | 04:23 AM
  #83
Terrys87's Avatar
Things are going great. Know how that goes trying to get things to the shop. It will eventually happen. Hang in there on training, hope it will fly by for you.
Old Feb 22, 2012 | 05:42 PM
  #84
redneckzombie21's Avatar
nice build. iam about to start my 3 rd build picked up a 88 with 22re for 400. has a really big hole in the side of the block. i have a 22r fully rebuilt out of my 86 that i did the cummins diesel 4bt custom twin turbos swap on. i am thinking of punting the 4.3 out of my 98 s10. i have all ready rebuilt 4.3 bored out 20 over mild cam. holly intake with mutl point fuel injected. (instead of the crappy spider injectors for the factory) also doing a 3.5 inch body lift and 2.5 suspension lift
Old Feb 22, 2012 | 06:44 PM
  #85
racerflea's Avatar
Nice truck man im scribed!
Old Feb 23, 2012 | 04:42 PM
  #86
RMP8080's Avatar
Thanks, the 4.3 V6 sounds great, with the 20 over and MPFI, should have a lot of power. best of luck...
Old Feb 23, 2012 | 04:43 PM
  #87
RMP8080's Avatar
Thanks
Old Feb 25, 2012 | 03:18 PM
  #88
the 4.3 ran great in my s10 i only have 7,600 miles on the motor since the rebuild. its a u joint barker with the 16 lbs racing clutch i can brake a u joint any time. i dynoed the motor at 366 a year ago. might even turbo it since i have one laying around
Old Feb 25, 2012 | 09:05 PM
  #89
RMP8080's Avatar
Maybe a supercharger?
Old Feb 26, 2012 | 05:01 AM
  #90
Terrys87's Avatar
Turbo and superchargers are over my head but it would be nice to see one done.
Old Feb 26, 2012 | 05:26 AM
  #91
yota721's Avatar
that would be awesome to see a turbo/supercharged 4.3 in a toyota!!!
Old Feb 26, 2012 | 05:53 AM
  #92
MrJaron93's Avatar
Indeed that would be a sight to see.
werent some of those chevy cyclones supercharged?
If somebody were lucky enough to swipe an engine out of one of those it would be sick!
Old Feb 26, 2012 | 01:15 PM
  #93
i have a 66mm turbo charger i can put on the 4.3. tune it to around 7 to 9 pounds of boost would work great. if i do it i will have to put a set of arp head studs in. my cummins in my 86 i run around 45 pounds of boost wide open. i need to get a camera so i can put pics on hear
Old Feb 26, 2012 | 04:51 PM
  #94
RMP8080's Avatar
Well I got a new seat driver side, need to find a matching one for the other side
Old Feb 26, 2012 | 04:59 PM
  #95
RMP8080's Avatar
Question do I need this?
Old Feb 27, 2012 | 06:29 AM
  #96
Terrys87's Avatar
Seat looks comfy. Are you talking about the Stablizer bar ( if that is what it is called) or the extention? My 79 has the same thing as it is a solid axle. I am not sure if it is needed, but on a solid axle, there really is much help holding it solid except for the springs.
Not my strongest area but thought I would try and give my 2 cents. Also get you bumped to the top of the list so someone else may give you a better answer.
Old Feb 27, 2012 | 07:49 AM
  #97
racerflea's Avatar
Its used to stabilize your truck not really needed for trail only rigs but if your planning on streeting it i would sugest yes
Old Feb 27, 2012 | 02:44 PM
  #98
RMP8080's Avatar
Thanks, I seen a few SAS without it and was thinking if need, would it be in the way of my V6
Old Feb 27, 2012 | 02:46 PM
  #99
RMP8080's Avatar
thanks, Terry
Old Feb 27, 2012 | 03:35 PM
  #100
RMP8080's Avatar
well we started the 4.3 V6 re-build....finally
planning to take it to the shop Thursday, it's going to need a new cam and lifters.
MORE TO COME
