RMP8080 1987 Pickup Build-Up Thread
Old Feb 27, 2012 | 05:26 PM
  #101
yota721's Avatar
nice looks good
Old Feb 27, 2012 | 06:59 PM
  #102
racerflea's Avatar
Put double rollers on it that way you never have to worry bout it
Old Feb 28, 2012 | 08:54 AM
  #103
Terrys87's Avatar
Thursdays probably feels so far away right now. Hang in there.
Old Feb 28, 2012 | 04:00 PM
  #104
RMP8080's Avatar
Ok, heads will be sent out tomorrow, the block still has the crank inside. hope to get it Thursday, however, work 16 hours Friday. good news off Saturday.
pictures of the engine...............from tonight.........
it appears that this 4.3 V6 had been re-build before. the engine was removed from a boat and no history. It looks like it needed a rebuild, so that may have just replace the V6....
still I have another V6 4.3 just in case
Old Feb 28, 2012 | 04:59 PM
  #105
jiffylubej42's Avatar
Crank and block look decent hope that their within specs.
Good luck, Jeff
Old Feb 28, 2012 | 10:22 PM
  #106
oneIwilly's Avatar
I was doing some cutting and measuring today on my truck.I found that with the core cut and some of the metal removed around the radiator area that a s10 4.3 radiator fits almost perfect.So hang on to one if you have it.Im going to use one with my 350.
Old Feb 29, 2012 | 02:12 PM
  #107
RMP8080's Avatar
Good luck, Jeff
Thanks, Jeff. News from my son is that one of the heads may have a crack near one on the plugs, not sure right now, we will send it out to a shop for more information. I still have another complete block if needed
Old Feb 29, 2012 | 02:16 PM
  #108
RMP8080's Avatar
I have a new Aluminum 22R radiator, hoping it will keep the 4.3 cool. Thanks for the information
Old Feb 29, 2012 | 02:58 PM
  #109
yota721's Avatar
hope everything works out
Old Feb 29, 2012 | 04:42 PM
  #110
RMP8080's Avatar
Thanks, yota721,
Never had a doubt, the more problems the more knowledge
Old Mar 1, 2012 | 11:56 AM
  #111
yota721's Avatar
yea because once you deal with the problem you have more knologe on how to fix it
Old Mar 1, 2012 | 03:37 PM
  #112
RMP8080's Avatar
the heads from the boat 4.3 V6 are cracked engine had overheated.
started on the other 4.3 removed both heads and will be at the shop tomorrow.
The Block should be sent soon, may get it done for free...........
Pictures of the other 4.3.............
Drivers side head
Good thing all the heads are the same (numbers matched)
Old Mar 1, 2012 | 03:53 PM
  #113
racerflea's Avatar
Cool! Hope things work out for the best!
Old Mar 1, 2012 | 07:32 PM
  #114
That sucks about the other motor being junk, I hope the next one will work out and have no problems.
Impatience never comanded success, so just keep on keeping on, Jeff
Old Mar 1, 2012 | 09:54 PM
  #115
Terrys87's Avatar
Ouch on the cracked heads, at least you still have others and they match. That would be great on getting the block done, always helps for the next steps. Hope things go a little better this go areound.
Old Mar 2, 2012 | 12:27 PM
  #116
RMP8080's Avatar
Thanks all for the comments. Basically the Boat 4.6 block I'm using (hope to use) it's going to my son's friend's shop soon. (FREE) The Heads from the other 4.3 look ok, and we will know soon. Before I buy parts for the 4.3 I'm waiting on news on the block.
I also has a 350 V8 just in case
Now for the tranny (GM TH-350) My son got permission to re-build it at school as a project for class (that will save me some money...lol) It will be a manual shift automatic
The transfer case is a toyota one and looks great so nothing there.
Already has the adapter between trans and t-case
This setup was from a 4.3 V6 toyota pickup swap that had major frame damage (RUST)
Old Mar 2, 2012 | 03:25 PM
  #117
redneckzombie21's Avatar
are u going to do any performance adders on the 4.3
Old Mar 2, 2012 | 04:16 PM
  #118
RMP8080's Avatar
Just a few, looking at cam, valves and Performance Distributor.
may upgrade the TBI injectors
Old Mar 2, 2012 | 05:46 PM
  #119
the 4.3 i got. i did performance cam. port and polished heads, performance valves, springs and lifters. all gear timing, holly intake with mutl point fuel injected, custom tuned ecm, arp head studs. all the motors i buld i use them
theirs a lot of power to be maid out of the 4.3
good luck.
Old Mar 4, 2012 | 10:37 AM
  #120
RMP8080's Avatar
Update:
We will be using one of the heads from the boat 4.3 (it has no problems) and the other from the other 4.3. it driving me nuts, but I guess it's ok. waiting for information on the block, soon I hope.
Did not do any thing to the toyota yesterday, worked on the F-350 and changed the oil in the Jetta. only had Saturday off, working thru to Friday. Overtime.....yep money for toys for the toy
Received my Differential Armor (on Sale: $28.35) from addictedoffroad for the front and will get on for the rear
