RBx 1988 4Runner Build-Up Thread
Old Apr 25, 2013 | 06:54 AM
  #1401
irab88's Avatar
dat axle...
how are you doing your extra stud holes for the e-locker? i have a hf drill adapter if you want to use it, but i would have gone with the long-drill-bit-down-the-existing-hole method (after doing mine).
Old Apr 25, 2013 | 06:59 AM
  #1402
RBX's Avatar
RBX
^^^ I will use my drill press for the extra studs. I'll create a jig to hold the press and axle straight....well that's the plan. Thanks for the offer. This is another reason to do this off the truck.
Old Apr 25, 2013 | 07:18 AM
  #1403
irab88's Avatar
yeah, i couldn't even do the e-locker by itself on-truck. i assume you already have the m8x1.25 tap? you can borrow mine if you need one
Old Apr 25, 2013 | 07:37 AM
  #1404
RBX's Avatar
RBX
...thanks again...Already have the tap.
oh, what part number was the gasket you used for the elocker to axle? I have had a few different part numbers.
I'm going to try to grab a hi-pinion also, and need to locate a part number for that elocker as well(I think they are the same, but i can't find any definitive information).
Old Apr 25, 2013 | 08:48 AM
  #1405
irab88's Avatar
i didn't use a gasket for the rear, just as a template (you can have mine if you want, if i still have it). i ordered from low-range, so whatever they put on their site
edit: for sealant, i used permatex red, works great, no leaks anywhere. and low-range states:
Flip gasket around for use with either standard pinon e-lockers and High Pinion 3rd members.
so i think you're good with getting two of the same
Old Apr 25, 2013 | 10:11 AM
  #1406
RBX's Avatar
RBX
^^^ good to know....thanks man.
Old Apr 26, 2013 | 11:48 AM
  #1407
RBX's Avatar
RBX
better shot of the hub freshly PC'd
Old Apr 28, 2013 | 02:14 PM
  #1408
RBX's Avatar
RBX
Found a local, hour away, public road.
I need lockers....
Old Apr 28, 2013 | 02:36 PM
  #1409
ChefYota4x4's Avatar
Duder, how u been?
My cameras often do the dame thing to bright colors, especially primary colors. White balance, noise, brightness all can bring drama with digitals, lol. My Canon-D, not so much, hehe.
Old Apr 28, 2013 | 02:54 PM
  #1410
RBX's Avatar
RBX
Been fine , thanks for askin.
Oh and I need a creeper gear truck is tooooo fast in 1st
Old Apr 28, 2013 | 05:43 PM
  #1411
RBX's Avatar
RBX
Oops love tap on the rocker should've finished those sliders...
Old Apr 28, 2013 | 05:46 PM
  #1412
RBX's Avatar
RBX
Ready the rear axle for the elocker
Old Apr 28, 2013 | 06:04 PM
  #1413
RBX's Avatar
RBX
Couple pics from today. This pic doesn't do it justice, but there is a small stair step section that I bounce through in the vid above.
Old Apr 30, 2013 | 07:16 PM
  #1414
Adams92yota's Avatar
Awesome man! Just finished reading all 57 pages. Love your build! keep it up
Old Apr 30, 2013 | 07:34 PM
  #1415
ToyoTech559's Avatar
nice video. you went pretty fast. should look into regearing and see if it slows you down enough for what you do. you will love the elocker. i only engage mine after i cant make it open. keeps the wear and tear off the tires since you really dont need to me locked the entire trail
Old May 2, 2013 | 11:34 AM
  #1416
RBX's Avatar
RBX
Thanks guys for the kind words.
Toyo...I am regearing and moving up to 35's, hopefully that helps, if not i'll get a creeper gear for my t-case. I can't wait for my elocker install. I may have a line on a front HiPinion elocker as well.
Not working on my truck is now becoming a real problem...I have almost every part I think I'll need and cannot start work till I have ALL the parts...maybe a week out from torching the IFS off.
I have been prepping parts, and modifying the axles for the elockers, but i guess i didnt take any pictures...DOH!
The work and progress will be bubbling soon.
Old May 2, 2013 | 12:08 PM
  #1417
kornhuskerwizard's Avatar
Nice looking hubs! I love the elocker mod, nice work!
Old May 4, 2013 | 12:03 PM
  #1418
RBX's Avatar
RBX
Torch has been delivered....
Old May 4, 2013 | 02:35 PM
  #1419
gonna be sweet. front and rear elocker!!
Old May 5, 2013 | 12:44 PM
  #1420
Oh mannnnnn! I am so excited for you!
