RBx 1988 4Runner Build-Up Thread
Old May 6, 2013 | 03:10 AM
  #1421
RBX's Avatar
RBX
Did a few small things this weekend in preparation for the SAS....
Painted the links:
Steering stop added 5/8" nut:
Steering stop capped off:
What's this? ...psssst its a baffle to stop the gear fluid from leaving the differential during cornering, the front never had one because the vehicle was not fulltime awd.
Old May 6, 2013 | 03:32 AM
  #1422
irab88's Avatar
rear axles have it too. it's to keep the gear oil in the dif compartment when going around turns. i have both in my rear axle. you can run without them, but i keep 'em in for peace-of-mind.
Old May 6, 2013 | 03:54 AM
  #1423
RBX's Avatar
RBX
I'm an idiot...I promise I'll get the tank out after work and send you the specs...sorry.
Thanks for the info, makes sense that the axle has those baffles in, but my front axle didn't come with any, i wonder if it should have...i can probably find them at the pick-n-pull.
thanks
Old May 6, 2013 | 04:41 AM
  #1424
irab88's Avatar
no rush on the tank. i still need to get myself a commuter car before i add things like that.
anyway, i don't think i've seen too many front baffles, though it wouldn't hurt to add some. great progress, by the way. absolutely awesome weekend for working on that stuff, too. is that por-15 on the links?
Old May 6, 2013 | 04:50 AM
  #1425
RBX's Avatar
RBX
That IS POR-15....love that stuff.
The silver, however, is Chassis Saver:
My local body supply carries both, while Chassis Saver is cheaper, and comes in a few different colors, I thought I'd give it a shot.
This weekend was really nice, I really got very little done to get ready to cut the IFS off. I spent a good amount of Sunday welding 1/4" - 3/16" steel scrap to practice my welds, and get the mig dialed in. I'll use my puny Lincoln 125 to tack everything, then I'll borrow my friends Miller 211(<< i think..) to burn everything in.
I also killed a good amount of time getting familiar with the torch. To me, these practices are essential for my project.
Old May 8, 2013 | 06:31 AM
  #1426
RBX's Avatar
RBX
Wheel Bearings
So I am swapping two new axles under my rig, one of which is a full-float rear.
this means I'll be able to use the same bearings at each corner. The best price I could find for Koyo(Japanese OE supplier for Toyota) was about $40 per corner. That is 8 bearings, inner and outer...until Monday.
carpartsdiscount.com
I paid $127 including shipping for all 8 bearings for all 4 wheels...and KOYO no less. this was by far the cheapest I have found.
I just realized it was cheaper for me replacing the rear as a full-float, bearing wise, then the semi-float single bearing...everything else...not so cheap.
first time i ever ordered from the above merchant, quick shipping, I have no affiliation with them.
Old May 13, 2013 | 10:38 AM
  #1427
RBX's Avatar
RBX
And then...
Old May 13, 2013 | 10:51 AM
  #1428
irab88's Avatar
Originally Posted by RBX
And then...
at first i was all then i was like Name:  smokin.gif
Old May 13, 2013 | 11:21 AM
  #1429
ChefYota4x4's Avatar
Woohoo! Cant wait!
Old May 13, 2013 | 11:58 AM
  #1430
chuntr's Avatar
Dang, you just dropped the entire IFS with the diff and axles still on? That must have weighed a ton!
Old May 13, 2013 | 04:54 PM
  #1431
RBX's Avatar
RBX
Thanks guys.
Didn't weigh a ton, probably 200lbs. I used a motorcycle jack as a cradle. Now I'll drag it out back to scavenge a few things
Old May 13, 2013 | 06:31 PM
  #1432
irab88's Avatar
lemme know what parts you have left over. i might need a trail spare of something for the time being.
Old May 13, 2013 | 07:06 PM
  #1433
RBX's Avatar
RBX
Will do, I will be keeping some stuff.. Brakes, hubs..
Old May 13, 2013 | 09:54 PM
  #1434
Ocell's Avatar
Looks like the no-nonsense way to drop the IFS kit out of the front. I'm looking forward to seeing your process on the SAS!
Old May 14, 2013 | 05:08 AM
  #1435
JSchumada's Avatar
You need to invest in some bigger jack stands!! LOL
Old May 14, 2013 | 05:25 AM
  #1436
RBX's Avatar
RBX
^^^ yes, but just to be clear, those stands infront are welded to the ramps, and the little jack on the pavers, is only holding. The Trans, so it isn't stressing the motor mounts.
Old May 14, 2013 | 06:14 AM
  #1437
liveoffroad's Avatar
hey RBX,
lookin good, your past the point of no return haha.
On your rear FF conversion, does that add width to your rear axle or does it come out the same in the end?
Old May 14, 2013 | 06:31 AM
  #1438
Ocell's Avatar
I'm so glad you mentioned that. I was stressin for you a bit.
Old May 14, 2013 | 07:22 AM
  #1439
RBX's Avatar
RBX
Originally Posted by liveoffroad
hey RBX,
The Ruff-Stuff Flanges are flat on the back, so you will need to machine them down to match the axle(makes it easy to center) or extend your axle width by doing something else. My WMS to WMS will be 58.25" if our calculations are correct. in essence i am loosing .25" on the rear axle.
Old May 15, 2013 | 06:13 AM
  #1440
great thanks for the info.
just curious, what made you go with the ruffstuff kit over the FROR bolt-on kit?
