rattlewagon's 1992 Pickup Build-Up Thread
Old 07-27-2023, 06:22 AM
  #701
rattlewagon's Avatar
Originally Posted by habanero
Those little words on the exo...
Way back, my step dad was rebuilding the mechanical fuel pump on his mini-ex and had is sitting very carefully on the back of the machine waiting for parts. If it was picked up or moved, parts would fall "in" and he would have to take it apart again. So he put a sign up so people wouldn't move it or pick it up, and the sign said just that. We took a picture and had it made into a sticker.. haha.
Need one? I have a few more still.
Old 07-27-2023, 06:24 AM
  #702
Originally Posted by Hairyberry
This rig is rad I’ve been reading through the build and I really dig what you’ve done, I’m glad I skipped the rebuild the 3.0 part with mine. The 3.4 seems like a night and day difference but then again I never had the 3.0 running at 100%
Thank you!
I agree. I was a 3.0 fan UNTIL I got the 3.4 in, then I wished I did it years ago.
Old 07-27-2023, 06:58 AM
  #703
habanero's Avatar
And it has a story? Awesome!
When it's not broken the blue thing is my daily driver, being an elementary school lunch lady I'd have to store it until I retired...
How fun would it be if the kids were to sound that one out?
Old 09-12-2023, 07:27 AM
  #704
Duplicate post.
Sticky tires are a fun! That is all.
The following 2 users liked this post by rattlewagon:
habanero (09-12-2023), Hairyberry (09-14-2023)
Old 01-01-2024, 04:12 PM
  #705
Reds have been great in rocks, less in mud. Played around with sticky treps on the back which seemed to work pretty well.
Cheapy amazon rock lights.
I needed to replace a broken hub stud, and figured it was a good time for an upgrade. I removed the 3/8 stud and cone washer in favor of a 7/16th stud.
a 1.25 length was just about the perfect length as the stock length, the allen heads so you can still get the wheel on.
Drilled all the holes to 3/8, then to 25/64th, which was the size the tap called for.
Tapped to 7/16 -20, Hubs needed to be drilled to 29/64th to clear the 7/16 stud. It takes up just about all of the taper, really fits the larger bolts well
On and torqued to 70lbs. Absolute thrilled to have gotten rid of the cone washer here.
I ran into a little problem here as I could not drill through the TG chromo drive flange. Even bought a "hard metal" bit from the local hardware store and didnt touch it. So I went back to locking hubs with chromo gears for now. I did have to drill the back of the hub out too to match the extra dowel pins from the drive flange.
The 3.4 may have a cracked head or start of a HG going. Lots of wheeling coming up this winter so well see how long it lasts.
habanero (03-13-2024), rustED (03-10-2024)
Old 03-12-2024, 03:56 AM
  #706
Headed down to Mass for the annual Northeast Toyota Crawlers Club meeting this past weekend. Meeting was great, we have a good schedule for this year and a good group of wheelers. They didnt have much snow but I left the chains on anyway but apparently they hooked a hopped a little to hard.
Took out the rear output on the t case, a u joint and bent a rear leaf spring... oof. But I was able to drive out still in front wheel drive.
Got it a part Sunday
I had to cut off that spiral gear and the bearing. The shaft was broken and not connected to the 4wd gear, but WOULD NOT come out and that black spiral gear would not move.
Old 03-12-2024, 03:58 AM
  #707
Put it back together as much as I could last night, just used another stock output because I had one on the shelf. I need to crack open a parts case for that spiral gear and bearing, then I can put the rest of it together.
Looking at where it broke, it appears to have broken right on the last oil port.
habanero (03-13-2024), rustED (03-13-2024)
Old 03-13-2024, 02:22 AM
  #708
habanero's Avatar
I've been looking at cheap rock lights, thanks for the pic.
And cone washers....bah! I'm not friends with mine either.
Old 05-09-2024, 04:56 AM
  #709
Fixed the bottom two holes in the v6 adapter plate that have stripped over time from install/removal
The ears on the DS were a little fubared from the u joint going, so chopped it off and welded on a "new" end with a factory toyota joint on it. Did my best eyeballing to get it straightish by rolling is on some casters.
Replaced the bushing on the Bombproof mount. But of course when I welded the mounts on from the bottom a few years ago, I didnt check how the bolts were. Had to cut one set to get them out. They go the other way now...
Rear springs fixed. Found a 2 year old set of 08+ chevys for cheap. They are the thicker leaves, but I ended up only using the main leaf, and putting my old bastard pack on the bottom and were back in business. (chevy main leaf, for ranger AAL, 2 toyota leaves, then a cut down chevy over load
Nix Mixin
09-23-2011 07:06 AM
redsyota
11
09-19-2011 08:34 PM
joez
02-01-2010 06:45 AM
Tanto
05-17-2007 11:29 AM
Quick Reply: rattlewagon's 1992 Pickup Build-Up Thread
