My 1987 SR5 ROAR (Restoration Of A Restoration) thread
Old Sep 29, 2023 | 02:10 PM
  #81
4Runner4Leon's Avatar
5 Year Member
Time to finish up the cooling system, so I replaced the heater hoses and clamps with OEM parts:
I filled the system with Toyota Long Life Coolant, and burped it:
Then buttoned it all up with a new OEM cap:
Old Sep 29, 2023 | 02:12 PM
  #82
5 Year Member
Here are some of the hoses installed, I still need to get a shot of the heater hoses:
Old Sep 29, 2023 | 04:32 PM
  #83
5 Year Member
So an interesting finding after replacing the heater lines - my heater now works! Woohoo! Not sure why - I had previously manually moved the water valve to the open position, and blew through the heater hoses to make sure the heater core was not clogged, and neither were the engine passages. Still no heat. I did the same thing again when I replaced the heater hoses, and voila, we have heat! No idea why, but I won't question success.
However, you'll be shocked to hear that the temperature control cable does not work. I can move the lever from cool to warm, and nothing happens to the cable inside the engine bay. So I'm guessing it's unhooked somewhere near the heater core? I think I read about that being a thing in these trucks. I have a new blower resistor on order (since it now only works on max), so I'll tackle these projects at the same time.
Old Sep 29, 2023 | 04:55 PM
  #84
wallytoo's Avatar
the blower resistor is easy to swap out. can be done without removing the glove box. i just swapped the blower in one of my '87s with one from my '88 parts rig. took about 20 minutes. added the toyota oem resistor at the same time, since low speed didn't work.
edit: i believe your hvac faceplate is from an earlier year (pre-1987).
Old Sep 29, 2023 | 05:04 PM
  #85
5 Year Member
Oh that's good to know, thanks Wally.
And yes, I remember you calling out the wrong faceplate during the auction - I have the correct one ready to put in. What holds them in place?
Old Sep 30, 2023 | 06:24 AM
  #86
5 Year Member
After watching this video, I figured I might as well order a new cable and clamp for the water valve, before diving into the project. There is a small chance that the cable is just disconnected, but seeing everything else on this truck, my bet is that it's broken. Might as well have the new parts on hand before tearing into it, to avoid doing it twice.
http://www.youtube.com/watch?v=d7ILP...rtyFingerNails
Old Sep 30, 2023 | 08:57 AM
  #87
wallytoo's Avatar
here are a few close-ups of the upper lid hinge...i have one of the four possible dividers that go in the upper bin (both 4runners have the double box).
and a pic of the blower resistor under the passenger dash..remove that screw, and the resistor pulls out easily.
and the blower - this can be removed without pulling the glove box, too. only have to remove the kick panel cover to get to the three screws (and you can see the resistor/proximity to the blower).
Old Sep 30, 2023 | 09:48 AM
  #88
5 Year Member
Thanks Wally! I can't find these on any parts diagram, but I'll keep sleuthing.
Old Sep 30, 2023 | 10:13 AM
  #89
5 Year Member
The engine bay is finally looking good:
I'm still taking care of a few other miscellaneous things with the parts I have on hand, while waiting for my $700 order to ship from Amayama...
Thanks to some awesome tips from @SomedayJ about how things were originally routed under the hood, I installed this clamp to hold the two idle up hoses together:
Next I replaced the aftermarket cruise control vacuum line with an OEM piece, and used a clamp to attach it to the air hose. Before:
Hose:
Clamp:
After:
Old Sep 30, 2023 | 10:19 AM
  #90
5 Year Member
I didn't like the aftermarket negative battery terminal. Since the original one is discontinued, I got the next best thing, a terminal from an Avalon. Not original, but still a Toyota part!
Before:
Avalon terminal:
Comparison:
Final:
Old Sep 30, 2023 | 10:25 AM
  #91
5 Year Member
On to Wally's comment about the HVAC faceplate. I bought just the label sheet, and I think you can also buy the entire trim panel. I would do the latter next time, that label sheet was a project to peel off.
New label:
Comparison:
The old label was very brittle, and broke up into many pieces:
After cleaning off all the residue, it was time to install the new one. To answer my earlier question, the label has pre-applied double sided tape, so it's easy peasy:
Back to OEM look:
Old Sep 30, 2023 | 10:30 AM
  #92
5 Year Member
And finally for today, I installed the replacement dome light assembly, since the original one was missing the lever. My original plan was to just swap the lever, since the original assembly was gray and the replacement is black. But the lever attachments appeared to be different between the two (despite the identical part number shown on back), so I just swapped the entire assembly:
I'll leave the painting project for another day. Just as I will the sagging headliner that I noticed when messing with the dome lamp. Sigh...
Old Sep 30, 2023 | 10:49 AM
  #93
wallytoo's Avatar
nice replacement of the hvac panel. i need to do that on both of mine - breaks/holes in both from 37+ years exposure/use.
for the power steering idle-up hoses, the clamp you installed is one part, but there is also a bridge that attaches to the head cover (valve cover).. the clamp is visible in both of the pictures, as is the bridge, mounted just forward of one of the vsv units.
Old Sep 30, 2023 | 01:48 PM
  #94
5 Year Member
Thanks Wally, it does look much nicer with the correct HVAC plate.
And thanks for the point about the idle-up hose bracket on the valve cover. I'm aware that it's missing, but it's discontinued. I've been trying to find a used one, but so far no luck. Got a spare?
Old Sep 30, 2023 | 03:15 PM
  #95
wallytoo's Avatar
i'm missing it on one of my '87s, too.
Old Sep 30, 2023 | 03:19 PM
  #96
5 Year Member
OK, I'll keep an eye out for two of those then.
Old Oct 1, 2023 | 06:53 AM
  #97
SomedayJ's Avatar
Glad I can help. Your 4Runner keeps getting better. Thank you for all the pics, OEM parts numbers and details.
Old Oct 1, 2023 | 08:39 AM
  #98
5 Year Member
Found out the hard (scary) way on a drive today that the horn doesn't work. Another project! The ratio of of what works on this truck vs what doesn't work is pretty sad.
Old Oct 2, 2023 | 07:28 PM
  #99
5 Year Member
Here's a first on this thread, a project that didn't cost any money! My buddy adjusted the clutch pedal and the neutral safety switch so that I no longer have to mash the clutch pedal all the way through the carpet to get it to start, and to change gears. Gotta love the freebies!
Before adjustment:
After adjustment:
Old Oct 3, 2023 | 07:43 AM
  #100
octanejunkie's Avatar
Yeah, not sure about that. I don't know the etiquette of BAT comments. As you know, the seller made himself sound like a very thorough ASE certified mechanic, with nothing left untouched, all top quality components, blah blah blah. I'll let this thread speak for itself in that regard. Believe me, you haven't yet seen the half of what's coming. But hey, it's a used car, caveat emptor, shame on me for not going up to see it in person.
For background, here is how I work on my cars, and how I expected this truck to be. These are photos of my 3rd Gen's engine bay refresh project. Everything I touched was painted, powder coated, or replated. All OEM hoses, clamps, brackets, etc.
When I'm done with Lucy (the 1st Gen), she'll be like this if not better. But it'll be quite the long road.
Leon, your attention to detail and quality is not lost on us. Lucy is in good hands. Can't wait to see her emerge.
As far as BAT goes, I would contact them for sure with what you are finding. I have a friend that works for BAT I could ping to see what he thinks
