My 1987 4WD SR5 "Restoration Of A Restoration" thread
I just bought an '87 SR5, and am starting a long term restoration project on it. I figured I might as well document my work here.
I'm calling it the "Restoration of a Restoration" thread because despite being stated to be restored, almost everything in the truck needs to be redone to make it a truly restored vehicle. Everything except the paint job, thank goodness - that is truly well done. I'd love to get feedback and comments along the way. I never started a build thread of my 3rd Gen, and now 6 years later, I really regret that. So I won't make the same mistake again! So without further ado, here it is: https://cimg1.ibsrv.net/gimg/www.yot...42702d4e14.jpg https://cimg2.ibsrv.net/gimg/www.yot...102930509f.jpg https://cimg5.ibsrv.net/gimg/www.yot...195012ff0e.jpg https://cimg2.ibsrv.net/gimg/www.yot...637b7f98d0.jpg And here it is next to its younger sibling: https://cimg6.ibsrv.net/gimg/www.yot...d934b53636.jpg |
First order of business was to look for things that weren't working, and it was quite a list.
The clock always reset back to 1:00 after taking out the key. And the dome and map lights weren't working. After some googling, the obvious suspect seemed to be the dome fuse. Yup, sure, enough, it was blown. A new 7.5A fuse, and we've got a clock that retains memory, and a working dome light (I replaced it with a brighter LED bulb): https://cimg4.ibsrv.net/gimg/www.yot...179f25e924.jpg https://i.imgur.com/a8rRJR9h.jpg https://i.imgur.com/wjjiahch.jpg Next was the door lock switch that wasn't locking. I took the door panel off to examine the switch, but it had good continuity. Then I looked more closely at the connector, and there was the issue - one pin got pushed out and wasn't making contact. I pushed the pin back into place, and everything works now (except that the driver side actuator is a bit lazy in the locking direction, but that'll be a battle for another day): https://i.imgur.com/siOzZTKh.jpg https://i.imgur.com/g9PjDvah.jpg https://i.imgur.com/n8eqDf5h.jpg Gotta love these "free" fixes! |
Beautiful truck!
A lot of things are simple fixes on these old Yotas. |
Beautiful truck, I love that color.
Nice 4Runner!
Originally Posted by Melrose 4r
(Post 52486829)
Beautiful truck!
A lot of things are simple fixes on these old Yotas. You are right, most fixes are simple - but the spare parts (especially interior) are becoming really hard to come by. Much more so than on my 3rd Gen, I'm finding out. Still, I have about $500 of parts on their way to me as we speak :). |
Next I looked at the fluids. Power steering fluid was a mysterious mix of brown and yellow, I'm guessing someone added power steering fluid to ATF. So I did a full flush using Valvoline MAX Life Dexron VI. Turkey baster for the reservoir, fill with clean fluid, disconnect return line, turn wheel lock to lock, repeat until the fluid is clean. Easy peasy.
https://cimg2.ibsrv.net/gimg/www.yot...205e8239e7.jpg https://cimg3.ibsrv.net/gimg/www.yot...62b1900903.jpg https://cimg4.ibsrv.net/gimg/www.yot...77ab108f5c.jpg https://cimg8.ibsrv.net/gimg/www.yot...6335becc48.jpg https://cimg6.ibsrv.net/gimg/www.yot...b0713a7c34.jpg |
The windshield washer wasn't washing. Hmmm, could the pump be the cause?
https://cimg1.ibsrv.net/gimg/www.yot...594da1b970.jpg Ordered an aftermarket washer pump - https://cimg3.ibsrv.net/gimg/www.yot...ec1c9e8ce9.jpg Fit very nicely into the reservoir recess: https://cimg5.ibsrv.net/gimg/www.yot...836fc21be3.jpg I proudly reconnected the wiring, only to find that the washer would not turn OFF! A bit of further diagnostics revealed that the switch on the wiper stalk was stuck in the ON position: https://cimg9.ibsrv.net/gimg/www.yot...755f377841.jpg I pried out the push button, and found out a few things. https://cimg0.ibsrv.net/gimg/www.yot...5cb8b81a92.jpg One, it was sticking (duh); two, one of the tangs broke off (and then so did the second one when I looked at it); three, the spring was compressed completely flat and the push button had a melted indentation where the spring sat. So I'm guessing at some point the system short circuited (maybe when the pump went bad?), and the current through the spring melted the cap and deformed the spring. I was able to rebend the spring into a conical shape, but the push button will be a project for another day. https://cimg4.ibsrv.net/gimg/www.yot...9de109e94e.jpg |
The truck didn't start today, dead as a doornail or whatever the cliche is. Battery shows about 1V, ugh. It's dated 8/22. I recharged it, but now I need to see if it has a drain or is not getting a charge when running. Parasitic draw seems to be tiny, about 0.01A. So will need to check the voltage when I fire her up.
Looks like the battery is kaput, it's not even holding a charge. I'm thinking of grabbing a Costco Group 25 battery, does that sound right for this truck? https://costco.interstatebatteries.c...380&Country=US
Been chasing one thing after another. Turns out the 1 yr battery was dead because the alternator was charging it at 16.7 V. After some tests on the alternator, I traced it down to dead diodes. It probably didn't help that it was soaked in power steering fluid leaking from the pump above.
https://cimg3.ibsrv.net/gimg/www.yot...1ffdc841c9.jpg I considered rebuilding it, but after taking it apart, I found that it's been rebuilt before, and not very well: https://cimg9.ibsrv.net/gimg/www.yot...08e1725afd.jpg So I just ordered a remanufactured Denso alternator, 27060-35061-84. While waiting for that, I figured I'd rebuild that leaky power steering pump: https://cimg2.ibsrv.net/gimg/www.yot...c2ec5b15c9.jpg But after taking it out, I saw that it's a remanufactured unit, and I'm not even sure if it's original Toyota. So I ordered a new pump from RockAuto, BBB N990-0217, along with all four power steering hoses. With the power steering pump and alternator out, I have good access to the fan and clutch, so I ordered these. And now I'm pondering getting a new radiator, given that I'm already this deep in. Probably the CSF 2306. Like I said, the list keeps growing. |
In parallel with these projects, I decided to have a look at the windshield washer push button. With the cost of used stalks on Ebay pushing $200, I tried my hand at rebuilding this one. I made a U-shaped backup strap out of thin sheetmetal, and bonded it into the button with JB Weld 50139. I then adhered the two broken tabs to the metal tabs with the same epoxy.
https://cimg9.ibsrv.net/gimg/www.yot...d5812fe123.jpg https://cimg6.ibsrv.net/gimg/www.yot...6aea2b3015.jpg Ignore the yellow epoxy below, that was my first attempt with something I had on hand, before I switched to the plastic Bonder. https://cimg4.ibsrv.net/gimg/www.yot...97116002c2.jpg https://cimg4.ibsrv.net/gimg/www.yot...758fdb9c5b.jpg https://cimg3.ibsrv.net/gimg/www.yot...51cb87bef6.jpg https://cimg8.ibsrv.net/gimg/www.yot...7bfd33aa6f.jpg I popped this assembly back into the stalk - it fit very nicely and operated smoothly! https://cimg6.ibsrv.net/gimg/www.yot...2cc9f07801.jpg https://cimg9.ibsrv.net/gimg/www.yot...f80dbe0a0c.jpg For the ultimate test, I turned on the key and tried the spray - it worked! What a relief. So I think I can put a bow on this project and move on to other things. |
i'm curious if you'll be commenting on BaT about some of the things that have been subpar in this $$$$ 4runner. stuff that wasn't disclosed, like the washer not working (or maybe that was, i can't remember), faulty battery, fuses blowing, etc.
i hope for your sake you don't have to do so much to it, considering what the price was. nice fix on the washer button, too. i bet that will hold up. |
Today I tried to re-cover the black console lid with a gray piece I bought on Ebay. But after taking it apart, I found the foam to be too soft, so I am now in search of some high density foam. Until then, this project is on a backburner.
https://cimg9.ibsrv.net/gimg/www.yot...2e3604d5f6.jpg https://cimg8.ibsrv.net/gimg/www.yot...2ee2e8c5b7.jpg https://cimg3.ibsrv.net/gimg/www.yot...c9280f48a2.jpg https://cimg2.ibsrv.net/gimg/www.yot...4cd29df5ef.jpg |
So failing the console lid project, under the hood I went with my gallon of Simple Green, to get rid of all the old grease (hint, that wasn't enough). Worst of all was the power steering bracket, yuck. I really hate grease and sludge. I mean this is a Toyota, not an old Mopar (I can say that cause I love old Mopars :)).
https://cimg2.ibsrv.net/gimg/www.yot...bd4de3b3ef.jpg https://cimg6.ibsrv.net/gimg/www.yot...278d3105ba.jpg One thing led to another, and before too long, I had the whole radiator/shroud/clutch/fan stuff out (never to go back in), and most of the easily detachable brackets removed. I mean the more stuff I removed, the more other parts I saw that needed cleaning, so I had to remove them... and so on and so forth. I'm not sure what the coolant was, it was blue green... Somewhat of a science experiment, or more likely lack of any care in the past. https://cimg4.ibsrv.net/gimg/www.yot...c194dc6013.jpg The radiator has seen better days, it's got rust inside and the frame fell apart when I removed the assembly: https://cimg7.ibsrv.net/gimg/www.yot...e62ebce86e.jpg The shroud was not much better, someone cut off the lower corners for some reason: https://cimg2.ibsrv.net/gimg/www.yot...dcda4e09cd.jpg With that out of the way, I saw... more grease!! Did I say I hate grease? https://cimg3.ibsrv.net/gimg/www.yot...e5d3b5118f.jpg Some more quality Simple Green time: https://cimg2.ibsrv.net/gimg/www.yot...f48803d997.jpg And more grease! https://cimg1.ibsrv.net/gimg/www.yot...b34497b9b0.jpg The truck has clearly been through hell and back. Most of the fasteners I'm removing are either incorrect (wrong length, wrong head, etc), or are stripped. Here are some lovely examples: https://cimg4.ibsrv.net/gimg/www.yot...9da4baeaf6.jpg https://cimg7.ibsrv.net/gimg/www.yot...a81d8872a6.jpg Oh well, my Amayama cart keeps growing, it's hit four figures now :). Not sure what to think of the coolant hose hard line, it has a pinhole in it. I'm thinking it'll probably still seal, then again, with it out now, maybe I should just a get a new one? It's only money right? https://cimg3.ibsrv.net/gimg/www.yot...b69eecb42f.jpg https://cimg2.ibsrv.net/gimg/www.yot...9cb2c5b936.jpg https://cimg1.ibsrv.net/gimg/www.yot...7f1b57acee.jpg Well looking at these pictures makes it quite clear that a new hard line is in order. Ka-ching. |
i might have to use your washer button fix someday. this is the one in my '87 w/cruise:
https://cimg2.ibsrv.net/gimg/www.yot...77ef2478b8.jpg melted, just like yours. it still works, and doesn't seem to stick at all, either. howsomever, i've got this one in my '88 parts sr5: https://cimg0.ibsrv.net/gimg/www.yot...2ce4011163.jpg https://cimg7.ibsrv.net/gimg/www.yot...b28c877dc7.jpg no melting at all, so maybe i'll just swap it out when/if the other one fails. |
Originally Posted by wallytoo
(Post 52486926)
https://cimg2.ibsrv.net/gimg/www.yot...77ef2478b8.jpg melted, just like yours. it still works, and doesn't seem to stick at all, either. |
(Post 52486912)
i hope for your sake you don't have to do so much to it, considering what the price was. nice fix on the washer button, too. i bet that will hold up. For background, here is how I work on my cars, and how I expected this truck to be. These are photos of my 3rd Gen's engine bay refresh project. Everything I touched was painted, powder coated, or replated. All OEM hoses, clamps, brackets, etc. When I'm done with Lucy (the 1st Gen), she'll be like this if not better. But it'll be quite the long road. https://cimg5.ibsrv.net/gimg/www.yot...00bbb3dbf3.jpg https://cimg6.ibsrv.net/gimg/www.yot...ae197f64e4.jpg https://cimg7.ibsrv.net/gimg/www.yot...f3726c99e3.jpg https://cimg8.ibsrv.net/gimg/www.yot...11e7627adb.jpg https://cimg1.ibsrv.net/gimg/www.yot...190ad9f7e1.jpg https://cimg2.ibsrv.net/gimg/www.yot...0298f35ad7.jpg https://cimg8.ibsrv.net/gimg/www.yot...e6f65584f4.jpg |
you do some excellent detailing. a shame lucy wasn't really as finished as it appeared in the auction. proof is the poor condition of the radiator & shroud, and the filthy alternator. pretty deliberate that the engine bay photos didn't show those things, yet highlighted all the clean top half of it all. zero chance the seller didn't know about the condition of those items (along with the other things you are finding). discouraging.
(Post 52486939)
The one good thing I'll say about it is that the paint job is top notch (assuming/hoping the truck was properly prepped for paint). So that's one big item I'm hoping to not have to deal with. |
