Morph
Old Jul 6, 2010 | 07:44 AM
  #161
thook's Avatar
Getting Axleheimer's disease? Meh.....you get away from things for a while and you tend to forget the details. That happens.
Old Jul 6, 2010 | 08:43 AM
  #162
AxleIke's Avatar
Yup. A little bit of AxleHeimers! LOL!
Nah, I just don't have the time to post as much really, as I've gotten more and more active on local stuff.
Anyway, stay tuned for barbeque'd metal!
Old Jul 6, 2010 | 03:11 PM
  #163
Lysmachia's Avatar
Looks good Ike. Thanks for your help with my lights this weekend BTW!
Old Jul 6, 2010 | 07:47 PM
  #164
AxleIke's Avatar
Got some gussets made this evening, and started mocking up the center link. Also primed the frame yesterday, and painted today
Here is the mocked up idler, and a shot showing how I cut off the bracing:
And, I added some new bracing in:
Primed the frame yesterday:
Next it was on to mock up:
First I lined up a stock arm for reference:
Then it was on to the new arm:
Parts I'm using:
Mocked up, extended 1/2" to account for the extra steel on the frame now:
I spent the rest of the evening making gussets. I still have a few more to go:
I'll be using a piece of tube as shown to tie gussets into on the front side of the arm. Still have to make those though.
Also still have to drill holes in the main tube so I can rossette weld along the length of the tube.
Old Jul 6, 2010 | 08:06 PM
  #165
mightymouse's Avatar
niiiiiice! Can't wait to see the end result. scribed
Old Jul 6, 2010 | 08:15 PM
  #166
85gijunk4x4's Avatar
wow great job on the fabricating
Old Jul 6, 2010 | 08:23 PM
  #167
89silverpu's Avatar
Damn dude, that's badass...but with all this work, why not just swap out the front end and eliminate all the problems and make the whole front end that much stronger?
Old Jul 6, 2010 | 09:08 PM
  #168
Lysmachia's Avatar
Took balls to cut off that braciing Isaac. Us SAS folks could take a page from your book!
Old Jul 7, 2010 | 07:24 AM
  #169
AxleIke's Avatar
Thanks!
Old Jul 7, 2010 | 07:28 AM
  #170
AxleIke's Avatar
Well, it is a bit of work, but cost wise, much much cheaper.
This was 370 for the idler and 150 for the tie rod end parts, and the steel was stuff I had laying around, so I don't remember what all that was, but it wasn't too much because its short stuff.
SAS would be
900 for a new locker
700 for longs
500 for link material, brackets, and hardware
6-700 for coilovers
200 for gears
120 for new bearings
100 for a driveshaft mod
???? for tires and wheels
5-700 for high steer
and then add 900 if I want to go with a diamond instead of a normal LC front.
Plus, the body is still rough and crappy looking, and I still don't have cup holders!
It needs a lot of work before it can get SAS'd.
Old Jul 7, 2010 | 07:59 AM
  #171
AxleIke's Avatar
eh, not really. With the plasma its so quick and easy that I didn't really think about it. I knew I'd have to put more on, but this way it is all lined back up with the original hole in the bottom of the frame.
Old Jul 7, 2010 | 08:40 AM
  #172
thook's Avatar
SAS would be
700 for longs
6-700 for coilovers
200 for gears
Are you already running coilovers in the rear? And, are you planning on SAS'ing at some point? I'm guessing all of your prices are for new? I'm asking because I didn't realize an SAS was that extensive. And, why would you need new tires and wheels just to do it?
Old Jul 7, 2010 | 08:51 AM
  #173
AxleIke's Avatar
No. Coils in the rear. Thats a good point though, as my rear needs a 4 link now, as the 3 link I designed has a few flaws. Nothing major, but stuff that annoys me on the road.
SAS doesn't need to be that extensive, but I don't want a cookie cutter, every kid on the block has one, SAS. I also don't want to put leafs back on, even in the front, as I just went to all this trouble to get rid of them, because they annoy me.
And, yes, all my prices are new. Probably won't buy used stuff.
As for wheels and tires, I don't see too much of a point in SASing to run tires that I can run IFS. And also, beadlocks would be nice.
Old Jul 7, 2010 | 09:00 AM
  #174
thook's Avatar
Sorry....I'm not following. Are you saying you don't have coils in the rear? And, did you used to have leaf's up front?
Old Jul 7, 2010 | 09:13 AM
  #175
AxleIke's Avatar
I do have coils in the rear. I used to have leafs in the rear. You asked if I had coilovers in the rear, which I do not.
The front is still stock IFS.
Old Jul 7, 2010 | 09:18 AM
  #176
thook's Avatar
Oh, gotcha. Coils....coilovers....different. <<<ding, ding>>>
Thanks for clarifying. Onward through the fog, mateys.......
Old Jul 7, 2010 | 09:21 AM
  #177
Ardent's Avatar
He did a 3-link rear with coils.
He used to have leafs up front, then he did an IFS conversion to be different...
He's IFS and doesn't want to go to leafs if he does a SAS.
Edit: I'm slow.
Old Jul 7, 2010 | 11:53 PM
  #178
thook's Avatar
Oh, yer funny.....
Old Jul 8, 2010 | 07:08 AM
  #179
AxleIke's Avatar
LOL, yeah pretty much what Ardent said.
Old Jul 12, 2010 | 07:16 AM
  #180
AxleIke's Avatar
Got some more done. I now only have one tie rod left to make and I should be good to go!
Anyway, some progress:
First off, I "bologna cut" the center link sleeve and drilled it full of holes for rossette welds:
The bologna cut was at the suggestion of my buddy Kevin in RS, so as not to create a shear plane in the center link. Made sense and took all of 2 minutes to do, I'm liking it.
Then, after checking everything lined up, it was BARBEQUE TIME!!!!
The thermometer on the top of the grill read about 600F, but I'd imagine its only accurate to 50 deg at best. However, it was hot. I let the parts heat in there for 45 minutes, then pulled them out part by part and welded them up, with one 10 minute re-heat of the main piece in the middle of it.
Welded great, so I'm pretty sure my "tests" of the metal were accurate enough, by which I mean, it was a forged piece.
After welding, I put the whole thing back under the grill for another 30 minutes, and then shut the grill off, and kept the lid closed and let it cool. I think it was pretty slow cooling.
Anyway, I did not have a chance to shoot pictures while welding things up, as it was too rushed.
However, this is the finished product, checking for fitment on the truck:
I think some of those braces are a bit large, so I may trim them down a bit.
Here are a couple shots after doing a little clean up grinding, next to a stock unit:
I'm hoping this will result in a steering system that won't bend. I seem to have this knack, however, of not getting things to do what I want them to do.
Anyway, I also got one tie rod welded up, but don't have a picture yet. Not too impressive though, just a straight piece of DOM with two threaded inserts welded it, also with rossette welds.
