Mak92-4RnR's 1992 4Runner Build-Up Thread
Old Nov 21, 2011 | 01:44 PM
  #441
MaK92-4RnR's Avatar
haha i definitely will. i dont think it'll be that bad though.... i hope not atleast.
Old Nov 23, 2011 | 08:38 AM
  #442
MaK92-4RnR's Avatar
Here's a picture of the LC coils. Driver side ( gas tank side ) is the left one, obviously
Old Nov 23, 2011 | 12:14 PM
  #443
sc87yota's Avatar
^^^Like the video clip.
I remembered seeing a few rigs with stock front and LC coils while searching a while back. Couldnt find the exact one I was looking for (where it really looked like a hot rod) but these are close to the same(LC/stock).
Anyways I agree with you being that your rear is heavy this probably would be a good combo. Maybe have to get a lil bit longer panhard drop bracket?
Old Nov 23, 2011 | 12:27 PM
  #444
MaK92-4RnR's Avatar
exactly what im thinking. Im going to be putting the longer coil on the passenger side ( the spare tire and the gas tank are on that side. When i decide to pop these in, im gonna get new shocks, brake lines, a panhard and an lspv adjuster to top it all off. If it looks good and doesn't stink bug toooooo much. i'll leave it how it is. but if it does quite a bit, im gonna mark down where my T-bars are set currently, and possibly adjust them 1"
Old Nov 23, 2011 | 12:48 PM
  #445
sc87yota's Avatar
Right on.. I originally had a 4" PH drop bracket with my 2" coils and my rear axle was pushed to the side. I made a adjustable PH bar to center the axle. The adjustable bar worked but I had thoughts of it being unsafe so end up putting OEM PH bar back on with 2" drop bracket and it solved all axle centering problems and much safer! Why didnt I just get the 2" drop bracket from the begining? Good question... Can never learn enough from that search button up there Anyways my point being, obviously try to match length of drop bracket exactly to height in coil lift.
Interested in hearing/seeing how it turns out!
Old Nov 23, 2011 | 12:51 PM
  #446
MaK92-4RnR's Avatar
Well my truck is factory height right now ( the 2" coil leveled it out perfectly, i didn't even have to change the shocks out, I can still stuff my 33 ) so im gonna put the LC coils in, then order my PH depending on how much lift it gives me.
Old Nov 23, 2011 | 04:10 PM
  #447
MaK92-4RnR's Avatar
So this:
Led to this:
Which led to this:
Which ultimately led to this:
Oh and I got my Optima swapped out under warranty... ( it only lasted 6-7 months ) but they come with a 3 year flat warranty ( no renewals on the newer batteries ) So before the 3 year ends, im gonna burn up another one and get it replaced
Old Nov 23, 2011 | 06:15 PM
  #448
john4wd's Avatar
What led to what? need more info? Were the lights out of alignment? Is it illegal to have the HiLift jack mounted on the front bumper?
Old Nov 23, 2011 | 06:47 PM
  #449
MaK92-4RnR's Avatar
you're kidding right?
HIDs are illegal, got a ticket, swapped them back to stock.
Old Nov 23, 2011 | 09:02 PM
  #450
MKtaco_98's Avatar
guess you need to have mak follow you somewhere to really understand how bright those HID's were pics do them no justice
Old Nov 23, 2011 | 09:17 PM
  #451
john4wd's Avatar
That's a bummer you can't have those, Sorry to hear that :{
Old Nov 23, 2011 | 09:19 PM
  #452
MaK92-4RnR's Avatar
lol you "can" but because mine were bright yellow lights... its just a dead give away... i had white before and no one gave me problems.
Old Dec 6, 2011 | 10:43 PM
  #453
GabAlmighty's Avatar
Gotta love it, atleast you didn't get a VI (vehicle inspection) like they like to do up here in BC.
VI means you have to get your truck inspected. Chances are you'll fail for multiple things and have to get them fixed before you can re-insure it: mudflaps, flares, rust, lights out, the list goes on.
Old Dec 7, 2011 | 11:00 AM
  #454
91_TOYOTA_4x4's Avatar
Thats so lame dude Maybe you can make a custom headlight mod where u can have a stock bulb then drill in a spot for an HID and have a swith between em? He he!
Gab is right too. I see atleast once a month a truck on CL or bc 4x4 forsale or in need of something because of a VI... So stupid like go chase the idiots in the big trucks with 10" of lift blocks and a bent frame or something hah thats why my 4rubner is gonna stay pretty clean
Still thats lame!!!!
Old Dec 24, 2011 | 07:33 AM
  #455
MaK92-4RnR's Avatar
A little update. I picked up an 1989 FJ62 axle complete hub to hub. its a bit grimy from being 23 years old, and sitting outside but everything works! Here it is:
Old Dec 24, 2011 | 08:39 AM
  #456
ToyoTech559's Avatar
guess LT is out of the question now. nice SA. whats the diff between the FJ axle vs the hilux SA. still 8 inches?
Old Dec 24, 2011 | 09:14 AM
  #457
MaK92-4RnR's Avatar
Its just a larger differential, and a wider WMS. I believe the Fj60 differential is 9.5" and is IFS width. other than that, its the same as the mini truck axles. Same knuckles and hubs, but larger brakes, and longer axle shafts.
Old Dec 24, 2011 | 09:21 AM
  #458
dark_fairytales's Avatar
Nice score Mak. What did it cost you?
Are you going to link it or spring over?
Let me know if you would like some help with it.
Old Dec 24, 2011 | 09:30 AM
  #459
MaK92-4RnR's Avatar
I spent 280 on it! I couldn't pass it up... I had to drive to santa rosa to get it, but thats no problem. I enjoy driving.
Im gonna do a spring over conversion and leaf it. 3" TG front with 4" shackles should keep it nice and low... Im only going with 35x12.50s
But basically, Im gonna be going through the whole thing. Im focused on getting the armor welded on first thing, that way its out of the way, and I can clean it up/paint it once its rebuilt.
Im on the fence post about doing 6 shooter knuckles and longfields right now... 35s are no problem to these axles from the factory. but Doesn't hurt to do it all the first time, right?
Old Dec 24, 2011 | 12:10 PM
  #460
Nice axle buds! I like the sound of a 9.5" over an 8". Can u still get dirty 30's for it? If u can id go that way since its half the price of longs and you arent gonna beat it up and id say if ur doing axle shafts why not for 300 bucks get brandnew six shooters? They are brandnew and nice an strong.
Would be pretty sick to see it linked in te front though
